It goes in sleep mode and will not reboot. even when sleep mode is changed to never it still goes into a hibernation and you can't start the machine unless you unplug machine and reboot.
Remove ALL media, DVD, CD, USB, unplug, remove battery, plug in reboot. OR try to boot to safe mode, open the Control Panel, select Power Options, set to High Performance, Change Plan settings, set SLEEP and Hibernate to Never.
replace bios battery, reset the bios, insert required parameters after rebooting and when windows reboot change the time period for screen saver and hard disk shut down!
Go into safe mode Under settings, control panel, power options set "turn off monitor to never reboot
I think this is not a sleep problem but the incorrect monitor settings were set. This will cause the screen to go black when the OS comes up. Boot in safe mode and change the display settings to 640x480 OR in safe mode, delete your monitor. When you reboot it will load a default monitor and you should be OK
For that when you power up the computer press F8 key then enter in enable vga mode .
Then go to display property and set screen resolution to 1024*768 then apply and ok.
if still not work then try safe mode then uninstall graphic driver and reinstall.
When you power up the computer press F8 key untill you see windows logo.
Let me know if you need further assistance.
Thanks for using Fixya.
turn off everything and restart computer in safe mode,do this by holding down f8 as you reboot,then go in your setting and remove time limit on sleep mode.
I have a LCD panel it is connect to to the LCD. I need to change a setting on the computer to make it stop going into sleep mode, however, now that it's in sleep mode, how do I get out of that so I can make the change?
1. File manager in ipcsuite
/System/Library/SystemConfiguration/PowerManagement.bundle
2. Find the file:
com.apple.SystemPowerProfileDefaults.plist
Then rename it to:
com.apple.SystemPowerProfileDefaults.plist2
