Computers & Internet Logo
alexander martin Posted on Jun 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My external frequency is set wrong and should like to know what it is.Its an asus p4s8x-x hope you can help thank you
joecoolvette
Level 3:
  • Master 5,660 Answers
  • Posted on Jun 08, 2010
joecoolvette
Master
Level 3:
Answers
5660
Questions
0
Helped
2193284
Points
18014
The Asus P4S8X-X has C.P.R.
CPU Parameter Recall
(Central Processing Unit, or Processor)
Restart the computer, and BIOS will set the CPU parameters back to the factory default settings.
Internal frequency rate times the multiplier = external frequency rate.
The Asus P4S8X-X uses Intel processors (Socket 478) that have either a 400Megahertz Front Side Bus, or a 533MHz FSB.
Since you did not state what socket 478 Intel processor you have installed, I cannot tell you what the external frequency rate is supposed to be.
(At maximum operating capacity)
Have you installed a different Processor?
Were you trying to overclock?
What led up to this?
2helpful
3answers
Have asus p4s8x mob,when adding 3rd stick of memory (1gb) total of 3gb.computer hangs on startup 1long 3 short beeps. if i remove one old stick and leave new with old (2gigs total)it works fine,also works...
The Asus Asus Motherboards P4S8X-MX uses PC-3200 type memory and usually ships from Asus with 0MB of RAM. The Asus Motherboards P4S8X-MX supports up to 2GB of RAM. Maximizing your system memory will allow your Asus Motherboards to operate as fast as possible and offer the most productive environment.
RAM modules must be installed in special locations on the motherboard called Sockets. These memory sockets are what hold the RAM module in place and can range from 1 to 16 or more. Banks consist of a group of 1 or more sockets. A system can have 1 or more of these banks of sockets. If a system has more than 1 socket in a bank, a Kit must be purchased for that bank. A kit is simply more than one, usually 2 or 4, like RAM modules. All sockets in a bank must be filled, and for such systems we sell memory in a kit. Typically you will see 2x512MB or 2x256MB signifying you are purchasing 2 units of 512MB RAM modules or 2 units of 256MB RAM modules, respectively.
The Asus Asus Motherboards P4S8X-MX has 1 bank(s) which have 2 socket(s) in each bank for a total of 2 memory socket(s). This means the Asus Motherboards P4S8X-MX can support up to 2 individual RAM modules.
We recommend you purchase the largest capacity RAM module each time you purchase memory. The reason for this is if you decide to upgrade again later and all your memory sockets are filled, you will not need to discard the already installed lower capacity memory.
Below is a visual representation of the memory bank(s) and socket(s) configuration for the Asus Asus Motherboards P4S8X-MX.
Standard Memory Bank & Socket Configurationsocket_2.gif hope this helps John
P4s8x-x parts and name list
To know all about your ASUS P4S8X-X Motherboard, please refer to the product user manual, which can be downloaded from the following site
http://porthos.ist.utl.pt/ftp/windows/Drivers/asus/e1217_p4s8x-x.pdf
Hope this answers you questions
CreativeTECH
Advanced BIOS setting
I would suggest using the set bios default option on the main screen. This should reset everything to factory defaults.
Be sure to exit saving settings. After that, assuming there's no hardware damage, it should start fine.
Hope this helps. Please remember to rate this information.
Thanks
3helpful
2answers
Cant find sound driver for asus p4s8x-x
You can download the driver from the following link
Download ASUS P4S8X X Audio driver
I hope this will solve your issue.
Goodluck
If my solution proves useful please accept it.
Regards
Arjun
2answers
ASUS P4S8X-X
Yes, this is a RAM incompatibility since the motherboard don't support PC3200, you can check this link for the complete specs of this motherboard http://reviews.cnet.com/motherboards/asus-p4s8x-x-mainboard/1807-3049_7-30158119.html
Hope that helps.....
Don't forget to rate the solution FIXYA thank you....
7helpful
2answers
Asus p4s8x-mx support CD
If you want a copy of the CDs contact Asus by clicking here and ask if they can sell you a replacement cd for your model.
Instead of getting a replacement CD you can download and run the drivers from Asus download page here:
DRIVERS for Asus P4S8X-MX Motherboard
2answers
Usb
http://www.driverfiles.net/Bios/ASUS/P4S8X-MX/download/page,sh,29990,172,6,.html
download your drivers here
1helpful
Hello sir
Here is the web link
http://support.asus.com/download/download_item.aspx?product=1&model=P4S8X-MX
next time dont be so lazy and google it yourself!!!!!!!!!!!!!!!!!!
Grand Canyon Tech
Grand Canyon Tech
