1990 Lexus LS 400 Logo
Posted on Jun 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1990 LS 400 ? do I recharge the A/C with r12 substitute or complete replacement of system, parts? how to site anywhere?
Anonymous
Level 3:
Brigadier General:
  • Master 4,669 Answers
  • Posted on Jun 07, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
4669
Questions
0
Helped
1847617
Points
16674
If it has r12 in it just drain it out and recharge the system with R134A.
How do i recharge the air conditioner on my 1990 lexus 400
This is best handled by a shop which specializes in AC repair. I doubt you have the proper equipment to flush, lubricate and recharge the system. It isn't as easy as it once was when you screwed a can of refrigerant to the nipple on the low pressure side of the circuit.
4helpful
3answers
What type of freon i use for a 1990 lincoln town car?
R-12 if it has not been converted to R-134.....should be able to tell by valve on low side pressure fill tube...R-12 is getting hard to find....
My ac wont work
Must be Air-Condition System Lines/ Hoses leaking R12 Freon (gas).
MAYBE THE PULLY HUB BEARINGS FAILED OR
DUE TO VERY LOW R12 FREON (GAS ) will not work.
Because there is a switch in the receiver/dryer prevent AC from working when low R12 Freon present, to protect the system & compressor damages.
You must fix the leaks, before recharging it.
They must **** the old (residue) gases from the system & lines / hoses...... & stay in the vacuum pump 30 minutes to proof no more leaks.
Recharge some oil for the old type R12 Freon gas.
Before recharge it to 62-67 psi R12 Freon
See the web site like www.youtube.com/video site to see How they service & repair air-condition system?
Put the question to their search window.
This is the question u should.
Regards;
MAR
5helpful
3answers
DASH LIGHT
Coolant level is low
3helpful
2answers
How do I recharge the AC freon on my own?
You should have R12 freon in a 1990 but you can put R134 freon into that system the only problem your going to have is the adapter for R12 is different from R134 after you get the adapter you need to put the freon in the low pressure valve not the high pressure, you will know which one because the adapter only fits the low pressure valve which is located on your AC lines under your hood, theres a little cap thats either blue or black you unscrew. You can't buy r12 anymore because its not good for enviorment so buy R134. you can buy at any parts store for like $5 to $10.
I replaced the timing belt and water pump on my 1990 Lexus LS-400. Now it starts, but won't run. It will run on starter fluid. I have not yet filled the cooling system.
U NEED TO FILL THE COOLING SYSTEM AND SEE IF THAT HELPS.THE ENGINE HAS A COOLANT TEMP SENSOR THAT THE PCM USES(AMONG OTHER THINGS)TO DETERMINE HOW MUCH FUEL THE ENGINE NEEDS.IF THAT DOES NOT HELP RECHECK THE TIMING MARKS
I have a 1990 Lexus LS 400 and the brakes have failed. I replaced the master cylinder, the brake lines and now being told the ABS "brains" of the braking system needs replacement. Has anyone had this...
If the pedal is spongy you may still have air in the lines. If there are no brakes at all you may need to adjust the push rod for the master cyl. If the ABS has a fault it will set a code and the rest of the brake sys. will work normally
1990 LS 400 Brakes
you need to bleed them.
Top Lexus Experts
ROBERT GARCIA
ROBERT GARCIA
ZJ Limited
ZJ Limited
Are you a Lexus Expert? Answer questions, earn points and help others
