SOURCE: How do I get audio on my farenheit dvd-15?
Did you try tuning in to FM 88.7, this should pick up dvd audio
SOURCE: hi. I bought a used
Try setting the radio to 89.1 FM...that is what worked for us. Good Luck!
SOURCE: 2005 town and country mini van w/ farenheit dvd player
Some dealers installed a modulator for the radio; look under your driver's side dash to see if there is a small on/off toggle switch. If there is, flip it 'on', tune the radio to 89.1 and you should get audio.
If they haven't installed this, no problem. You can buy a modulator from most electronic stores that is used to play MP3 players through the car stereo; instead of an MP3 player, simply plug the cable into the headphone jack of your DVD player.
Make sure that the FM transmitter is enable. Use the remote and select picture; the last item on the menu is the FM transmitter; use the arrow button on the remote to set it to on. You can also change the freq of the FM transmission using this same menu.
