Question about GE 30 in. Profile JP989 Electric Cooktop
GE Profile JP989BKBB Blower is bust
The downdraft blower is not working. The motor seemed hot immediately after and something just below the motor seemed fused. The questions are:
1. How easy is it to replace the motor?
Any pointers on whether the entire blower assembly should be replaced or something else will help.
Posted by raob on
  • raob Apr 09, 2008
    Huh!
2 Related Answers
Anonymous
SOURCE: my ge ceramic cooktop hot indicator light won't go out
I know that some people have mentioned that it looks like it's on, even when it's off. Depending on how the light hits it, it can look like it's glowing a bit. This would be normal.
Posted on Apr 01, 2009
BarrettDenCo
Barrett Palumbo
  • 1772 Answers
SOURCE: OK, I have a cooktop that is discolored. Three
Sorry to read about your problem, I hope this helps you out.
you have to disconnected everything from the range, then take the unit out of the counter..will take 2 people
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Posted on Dec 21, 2010
I need a left front burner for a CP 220B Jenn Air electric downdraft cooktop: Serial no 069760DM. I also need a new blower motor, I think. Possible???
This is the first result I found; it may not have the best price:
http://www.appliancepartspros.com/jenn-air-range-cooktop-oven-burner.html
The site also lists blower motors, but be sure to verify that the motor is defective before ordering; they are very expensive.
Jan 17, 2017 • Cooktops
How do i fix a squeaky control knob on a ge downdraft cooktop?
silicone spray works wonders !!!! and most silicone's are food safe too (look 4 it on label) so its safe to use around food prep area's, it however does not taste 2 good to the human palate so use sparely
2helpful
OK, I have a cooktop that is discolored. Three years ago when I bought it the Yahoo that installed it did not install the foam gasket so it didn't sit well on the counter top. I called GE they sent out a...
The blower stops working
;blower motor gets to hot and shuts down. after cooling it runs again . this is bad brgs or tight brgs . you can try oiling brg or replace the motor . if older like you said i would repl the motor , this is a common problem as we repl a lot of older motors.. mm
Dec 12, 2009 • Cooktops
3helpful
My ge ceramic cooktop hot indicator light won't go out
Hello posted this question but family getting antsy without a cooktop. I am installing a 36 inch GE Profile gas cooktop, jgp970, along with a Frigidaire downdraft vent, pl36DD. The gas inlet pipe on the...
the reason for the fitting instruction for the regulator to be connected directly is that flex hoses deteriorate and allow a dangerous situation
AS gas is not in the diy domain I recommend that you get in an accredited gas fitter who will make a solid pipe to allow the fitment of the regulator away from the motor
While he is there he can adjust the regulator to get it all working correctly
Fan has difficulty turning, buzzes
Hi
Tha model is a Maytag.
There are a few things to check here, and it's best always to use the proces of elimination.
These are the things you need to check:
1.MOTOR, DOWNDRAFT
2.BLOWER ASSEMBLY
3.SCROLL, BLOWER ASSY.
4.CORD, POWER (MOTOR)
as you mention before sometime run and sometimes do not run.
youll have to start by checking those items and make sure they are not damage or obstructed. I have some wiring diagrams for that model, if you would like for me to email them to you, please let me know.
I hope that will help you
Eddie Rentas
Tupper Lake NY
Order in black w/matte finish grates & downdraft cover
No. If it is really important order the grates and downdraft cover as replacement parts. This will be expensive probably around $200 - $300.
5helpful
Jenn-Air 8130 installation problem
Rotate the blower to the proper angle
needed for your installation. The blower
can be swiveled 90°. To rotate the blower:
a) Remove the filter from the blower housing
b) Loosen, but do not remove, the nuts
around blower inlet.
c) Rotate the blower housing for the
proper angle.
d) Retighten the four nuts and install the
filter.
try this its general for this type of cooktop
Mar 30, 2008 • Cooktops
GE 30 in. Profile JP989 Electric Cooktop Logo
Top GE Cooktops Experts
Dan Webster
Dan Webster
Ekse
Are you a GE Cooktop Expert? Answer questions, earn points and help others
