Question about Cameras
My sony DSC-W35 keeps giving me a card error on the screen. in order to get any picture taken i need to keep changing mode and it still not work all the time. Also i got before some pictures that come oly half the image in view the other half was just one full colour. Can anyone help?
Posted by mayesse on
  • Anonymous May 11, 2010
    Have you tried to format your memory card? if that does not work then you might need a new card or the main board that reads the card has gone out. I fix these all thetime the pins tht read the memory cards can ware out.
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: DSC-T1 Lense malfuntion
sounds like you have a ccd problem (imaging chip)
Posted on Aug 29, 2006
Anonymous
  • 34 Answers
SOURCE: Very, very dark (almost black) lcd screen, but is functional
The LCD viewer is made up of the LCD screen, and the backlight. Your backlight is burnt out, or the circuit board isn't sending power to it. Backlights can be replaced separately.
Posted on Sep 05, 2007
Anonymous
  • 39 Answers
SOURCE: Windows 98 Driver required for sony cyber-shot dsc-w35
Windows 98 is not officially supported by Sony for the DSC-W35. You can find hacked versions on the web but they may not be stable. You can find a list of supported Operating Systems here at the Sony website. http://esupport.sony.com/US/perl/swu-list.pl?mdl=DSCW35&LOC=3
I would suggest trying to use the Windows ME drivers. Windows ME was based on Windows 98 so the drivers for most applications are virtually identical. I have used 8 different drivers from other vendors in situations like this and it worked out fine. However, please be aware that since it is not officially supported it can cause interoperability options with your Windows 98 system.
This is the best suggestion I have. By no means should you get Windows ME, it was one of the worst versions of Windows released. Lots of bugs and there are less drivers for this operating system than your Windows 98.
Posted on Apr 28, 2008
Anonymous
  • 3 Answers
SOURCE: My Dimage Z6 does not allow me to check the pictures taken.
i have the same problem. Did you get any answers? Thanks
Posted on May 21, 2008
Anonymous
SOURCE: File Error
my camara when I see or viewed the picture same of they are bad with lines and same videos says error and I can't see it
Posted on May 25, 2008
29helpful
2answers
When I turn on sony cyber-shot camera I get a screen display that states "access". The lens keeps going in and out and then it states,"turn the power off and on again" What's...
When I turn on sony cyber-shot camera I get a Problem with the Sony Cyber-shot DSC-W35 Digital Camera when I turn on sony cyber-shot camera I get a screen display that states "access". The lens keeps going in and out and then it states,"turn the power off and on again" What's wrong??
I cannot get my camera onto picture mode, it just keeps recording everything? Any ideas, as i have lost my instructions? thanks
You can download the manual from the manufacturer's web site at
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSCW35
3answers
When I turn on my Sony Cyber-shot DSC-W35 the screen is dark with the word "Access" on it, moments later it tells me to power it off adn on again, any ideas?
Its lens error in your DSC-W35 camera.
Lens mechanism is either stuck or not retract completely and system control sense this error. Please replace lens assembly to get it fixed because lens mechanism is not repairable.
Thanks.
1helpful
Sony Cybershot DSC-W35 Camera doesn't detect the USB cable
You dont need the disc to download to computer.Take the card from the camera and put it into the card reader on your computer if one is fitted, if not you need one that goes into a USB slot When the card is inserted into the reader a box will open on the screen with several options as to view images or download them.
I would also download Picasa 3 which puts your photos in date order and also has photo editing. This is a free download and is part of google.
Dennis Darwin
My sony dsc-s730 camera comes up with file error and a blue screen when i look back at some pictures taken, i keep losing really good pics to it how do i fix this?
Format memory card and check, if problem exist then replace memory card in camera.
Note: Format will delete all photo data on memory card so copy photo files before format.
I want to change the language on my camera
good luck,been there myself!!
keep "poking"around",eventually you will select"initialize",this will revert your camera to factory settings,and most likely "english"!
1helpful
3answers
Cyber-shot DSC-W35 format error c:13:01
Software for Memory error correction is available on charge basis to get data/ pictures.
Format error
Format memory stick, if no data on it.
If there is data on memory stick, copy it on PC using any good card reader.
I can't take pictures....
This error message TURN THE POWER OFF AND ON AGAIN is a common error message for digital cameras that has a zoom lens. One possible cause for this is that the battery may had drained out and the lens is still extended. There would be different that steps you could perform and make sure you have fresh or fully charged batteries when performing these steps.
First of course try to do what the error states.
If will not work, set the unit in PLAY mode before turning it ON or immediately right after you press the power. If it successfully gets through the PLAY mode, initialize the settings and restart th camera. You could initialize it by going to the menu and then setup.
If still will not work, turn it off and also remove the battery and allow it to have no power at all for a minute.
If all the steps above will still not work. your camera would require service and try calling its manufacturer to setup a repair on it.
Cameras Logo
Top Cameras Experts
Ekse
ADMIN Canada
ADMIN Canada
Are you a Camera Expert? Answer questions, earn points and help others
