Question about Lands Phones
Transfer to outside line with ancient phone help
I have a Panasonic EASA-PHONE system (ancient) and can't determine if I can transfer calls to outside lines. What I really need is to transfer directly to people's voicemails but it's a 10 digit phone number.
All manuals mention only internal transferring.
KX-T61610
Thanks in advance
Posted by bbradner on
5 Related Answers
Anonymous
  • 45 Answers
SOURCE: telephone user manual
It's listed here as a PDF file
http://support.panasonic.co.nz/manuals.asp
Posted on Jan 03, 2008
Amit Bhasin
  • 47 Answers
SOURCE: how to check your voicemail
download instuctions on this page... they are in a pdf format would help in resolving your problem.
URL : http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/Expandable-Systems/model.KX-TG6502B
Have a nice day !!
Posted on Apr 18, 2008
Anonymous
SOURCE: I have a Panasonic KX-T61610
Also, are there certain CO lines that can only work with this KX-T61610 system? Typical FXS? or any odd analog settings on CO lines or within the Key controller for the KX-T61610?
Posted on Jul 18, 2008
Anonymous
SOURCE: I need programing instructions for
For the onetouch buttons 1)push program untill memory light is on. 2) push desired onetouch button,
dial the phone number. 3) push auto button 4) when done press program button.
Posted on Oct 17, 2008
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: How do I transfer a call directly to voicemail?
If it's a Panasonic voice mail system you program a button for VoicemailTRansfer. Pick an unused button and label it VTR. Now, you need to know what the access number is for voice mail. It's usually 165 or 500. Then you press PROG the button and dial 94+ whatever number VM is and ENTER.
On the original installation, your installer should have at least given you 2 buttons, one for record and one for transfer. We usually give the customer a 3rd button called 2-way transfer. If your system is a TVA, there is a patch to record conversations as new messages, and if you have the optional LAN card(on the 50, it's already in the 200) for voice mail to email, it can send out the wav file at the end of the call.
Carl
Posted on Nov 24, 2008
CO 1 cannot call out or receives incoming.
Panasonic KXDT321 Phone
Conference call Call party 1 and speak
Press transfer
Call party 2 (press 9 for outside line if needed)
Party 2 answers
Press transfer then 3 speak to all three people
Repeat if required
Conference call
Panasonic KXDT321 Phone Conference Call
Press transfer
Party 2 answers
Repeat if required
On my KX-T7453 how do I transfer a call to an outside line?
What you said. It has to be allowed in programming, called Call Transfer To outside line. It's done by class of service and programming.
Carl
I receive a call from outside, press flash and dial the extension but it the person to whom I direct the call can not get the call and if I try to return to the call, it is disconnected.
The FLASH button is for outside calls. Try the TRANSFER button. If the inside party doesn't answer, press the outside line button that's flashing green. If you have a Panasonic brand voice mail, you can also transfer the call to voice mail with another button.
Carl
Kx 616 easa phone problem
Unfortunately, The KX-T 61610 system was made before featured cordless handsets were available, but any cordless (or any SLT for that matter) should be able to access any feature in the system providing it uses the SLT feature codes. I've added a Panasonic SLT users guide link for reference.
http://www.wedophones.com/Manuals/Panasonic/KX-T%20616/KX-T616%20Station%20User%20Guide.pdf
Automatic transfer to a mobile phone number
This question came up before and it works if you have a TA-824 as the system. http://www.fixya.com/support/t3120724-forward_calls_outside_number
The key is that you go to the intercom and dial 9 to get an outside line. If you get a line, you don't have to program 400 to disable the unused lines. After that, you enable outside line transfer, change the time for longer than 10 minutes if you need to, and dial the 7139 phone number # forwarding code.
Hope this helps. If you're using a different system and it doesn't, post back as a comment with your phone system model number.
Carl
Panasonic call id
first you must set the number of primary lines the phone can use from the phone setings..then try...
1helpful
Can I transfer voice messages to a cell phone
Yes and no (or maybe)
Your Norstar system is capable of outbound call transfers... transfers to people outside your phone system.
Most instances, the programmers shut off this feature of out bound transfers to protect your system from fraud.
A programmer will be required if you need this feature to work.
Otherwise, try this... outside caller calls in, (you want to transfer caller to a cell phone), press the TRANSFER button, pick an outside trunk (Line 2), and dial out, when you hear ringing, hang up.
The call will be transfered to the cell phone.
We want to transfer a call to a phone number (external party). System programming is required. Can you help me? Thanks, Gina
Panasonic KX t7730 call forwarding function to external party:
If you are using the Kx-TA624 pbx (TES 824 models) system, program your phone unit (t7730) as follows: lifet handset, press FWD/DND button, press 3, then the outside line access code, then phone number, then #, then return handset.
If you are using the kx-ta1232 (higher models) of pbx system (usually with 9 or more CO lines cabable, use the following command:
lift handset, press FWD/DND button, press 6, then the outside line access code, then telehone number, then # then return handset to cradle.
Lands Phones Logo
Top Lands Phones Experts
Ekse
Oloyede Monsuru
Are you a Lands Phone Expert? Answer questions, earn points and help others
