Nokia 6682 Handheld Logo
Question about Nokia 6682 Handheld
Nokia 6682 headset sign on all the time
I have Nokia 6682. The headset sign is on all the time and I can not use the regular speaker phone. I cant hear the voice on my phone without connecting it to headset. But I can hear beeps, alarm through the speaker.
Please help me with this problem. I greatly appreciate it.
Thank.
Kumar.
Posted by nidhi007 on
  • Anonymous May 18, 2008
    I dropped my phone yesterday and the same thing happened - phone would ring, but when I answered I couldn't hear the caller, and the caller heard only static instead of my voice. I took out the battery and left it out of the phone for about five hours. When I re-inserted the battery and turned the phone back on, the headset indicator was no longer visible on the LCD screen and the regular ability to hear and be heard through the phone had returned. I guess it re-set itself or something, but whatever, it is working fine now.
  • Anonymous Mar 29, 2009
    Had my phone for almost 3 years, its been really good. My earpiece recently stopped working so i replaced it with a new one, and then about a month later I suddenly got the headset indicator on at all times and can't use my phone as a phone anymore because i cant hear conversations or even speak to the other person.
5 Related Answers
Anonymous
  • 91 Answers
SOURCE: Head set icon on constantly...
Check the bottom of your phone. There is a connector down there, is there any greenish stuff (oxidation) on it ? If so, the connector has been exposed to water. Clean the connector as well as possible, it might have short-circuited the pins and the phone thinks it has the headset plugged in. You might have to take the phone completely apart and clean it from the inside. If theres no greenish stuff on/in the connector, you probably have to visit your local Service-Center for repairs.
Posted on Oct 05, 2007
Anonymous
  • 18 Answers
SOURCE: Nokia 3230 headset icon can't be removed
If factory settings didn't work,this will SURELY help:
1.Turn off your phone..
2.Press and hold three keys, i.e. Green Button(call answer key) + " * " button + " 3 " button and while holding the buttons boot the phone..
3.Hold till the phone shows the Nokia Logo/formatting screen..
The problem will be solved for sure..
Regards..
Posted on Dec 02, 2007
Anonymous
SOURCE: "Not Charging" and it says I have headset plugged in
My phone did this one time, i dont really remember how i got it fixed. If you havent already, take the battery out and wipe it off and the prongs that the battery goes in to. If problem is still there, you might need a new battery.
Posted on Mar 05, 2008
AvioriX
ExpressFiX
  • 689 Answers
SOURCE: Phone is Locked on headset setting even though there is no headset connected
best thing to connect a headset and take it out, that will trigger the function that it will come back to handset.
Good Luck
Posted on Mar 22, 2008
Anonymous
SOURCE: Nokia 3500 headset symbol in display
I have a similar problem on my phone, which is that when I insert my headset, it does not recognise it. And thus the music is played through the loudspeaker. And if it is recognised (luckily), then after I take it out, I see that the headset sign is still there. The only solution I have had is to turn the phone off and switch it on again. The sign should go away by then.
Posted on Oct 15, 2008
My nokia 6080 display headset simble i cant here the call
The headset reciever plug inside the phone is shorting out, or something is stuck inside the little hole. The phone thinks the headset is plugged in, therefore it will not emitt sound from the device speaker.
I have 2630 nokia phone i use my jabra bt 2070 for this one and then i bought a new phone 6120 nokia but i cant use the headset on it every time i search for jabra device my phone cant find it
First turn ON your bluetooth on phone, then hold on/off button to turn ON Jabra headset for 5 SECONDS, then vill light hold ON (NO BLINKING) and then find it on your mobile phone....
Hi from Serbia ;)
Unlocking of nokia phones
HI there please try these nokia unique pass code. 12345 its a passcode. Thanks.
Water damage to Nokia 6682 and won't turn on. Can
First never turn on any phone after be drop in water ! it's cause a electric shortcut and damage the phone.
I recommand to find a expert because the operation is manually and requeste a to be expert.
But if you can:
  1. open the phone
  2. clean it with a solution that can asperat and vaporate the water
  3. use some warm air to blow it over the chip like dryer
good luck;)
Increase external speaker volume
when the speaker phone is on, try pushing the up arrow, unless you have the button on the side, But I think it is the up arrow while talking.
Also go into regular menu settings, go to sound settings, speaker volume and headset volumes should both be turned all the way up.
May 30, 2009 • Nokia 2600
2helpful
2answers
7helpful
2answers
Nokia 6085 - unable to clear headset icon on display
i fixed this problem
The phone came with a headset. Plug the headset in and out a few times; it should reset the headset icon and phone can be used regularly again
Mar 21, 2008 • Cell Phones
Nokia 6682 keep turnig off by it self every few minutes
dont worry it caused by some virus attack in phone . first remove the memory card . then switch offf the phone . hold *,3 and green dial key together . then switch on the phone without relasing it . be sure all the keys are pressed firmly together . then the phone show a blank white screen for sometime then ask for time zone as if u buy it first time . if the roblem is solved format the meory card . the virus usally resides in memory card
Nokia 6230 Headset
hi. reset your phone settings to default and adjust for headset connection try to connect the headset to another phone and check if the mic is good good luck
Top Nokia Computers & Internet Experts
Marvin
Marvin
Muzahura Frank
Donivan Wise
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
