Question about Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine
Sewing machine motor seized up and broken parts near bobbin
Motor seized up in the middle of sewing, i tried to manually turn the wheel but it wouldnt move so i looked in where the bobbin goes, took it out and the inside where the bobbin goes was in in two pieces. i can piece the parts together and fit them inside but wasnt sure if this is the reason it seized up or the parts/or both?
Posted by nichole372 on
R.A. Ellis
  • Kenmore Master
  • 12,731 Answers
Difficult to say. The parts that came loose may be removable. Suggest taking it for service.
Posted on Nov 22, 2017
Don Eagan
    Master:
  • Kenmore Master
  • 714 Answers
Without actually seeing the problem myself I would only be guessing. I would recommend taking it to a Sew & Vac shot and get their opinion and a repair quote.
5 Related Answers
informatica
Greg Cann
  • 1114 Answers
SOURCE: putting the bobbin back together
You can download the manual from the link below: http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_xl3500t3510eus&type2=-1&flang=English&dlid= Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Sep 03, 2007
Anonymous
SOURCE: Sewing Machine
check if you are using the original bobbin... There are some similar bobbins but they are not the same...
Posted on Sep 05, 2007
Anonymous
  • 6 Answers
SOURCE: Bobbin Carriage clanking noise, yet the machine sews fine??
If your bobbin area is making a noise, then do NOT sew with the machine until a reputable technician looks at it. You may have thrown something just a little off line - not enough to affect sewing NOW, but it could easily cause troubles down the line.
I suggest you call ahead and talk directly to the repair person - not to the sales person. Ask if you can bring in the machine while he/she is in the shop so they can listen while you run it.
You aren't trying to cheat the store out of the repair charge, just ensuring that the problem is diagnosed correctly.
You paid lots of money for this machine - it deserves good care.
Posted on Dec 30, 2007
bargainbox
Hassy
  • 1388 Answers
SOURCE: Putting back the pieces of bobbin case on Kenmore Mini Handi
This is for front loading bobbin..........
The Shuttle hook will look very much like this, and marries this to the "half moon" of the fixed shuttle.
The retaining collar ring that holds it all together has a plate like protrusion (like bull horns), this faces to the top and to the back.......there should be a small lug (or two) with corresponding small hole or slot on the fixed housing (hook race) that locates the ring tightly in the correct position.
There should be 2 swivel arms (black plastic at 4 o'clock & 8 o'clock)) that move to hold the whole thing together by clipping onto a small lug on each side of the ring.
If you tip the machine 30 degrees on its back while you do all this, it makes the process easier, as things are less likely to fall out.........support the back with a soft object for convenience (tissue box, pillow etc)
The bobbin case goes in after the housing is assembled, if you try to do it first, it will prove more difficult.
If this is not quite accurate for your model a photo of the bits would be helpful
Posted on Feb 29, 2008
tribefan53
  • 3 Answers
SOURCE: I have a Husqvarna Emma sewing machine. The
I was able to gain entrance into the area by taking out 1 screw (star head), slightly pulling on the plastic compartment to cause a small opening. I then tilted the machine and the needle fell out. The screw is located on the rear of the sewing machine, right behind the bobbin compartment. A flat head screw is also needed to "Pry" open the plastic.
Posted on Apr 19, 2009
White Sewing machine won't start. Makes the whirring noise but will not advance fabric. I've tried moving the bobbin spool back and forth but it still won't start.
If your machine is not broken, it most likely is seized due to old oil that has hardened. How long since its last service? Refrain from trying to run the machine until the issue is resolved as it could damage the motor. or more...
Wheel on right side that controls the needle up and down is very tight...
Aug 29, 2017 | White Sewing Sewing Machines
Singer 3232 machine was sewing fine now motor runs but needle does not move up and down
Check if the machine is in the bobbin winding mode. To wind the bobbin, the bobbin spindle has to be moved to the right. (The hand wheel will not turn if the bobbin spindle is in this position.) If it is, move the spindle to the left.
If the hand wheel turns, then check for a thread jam. Remove the top thread and take out the bobbin case. Gently turn the hand wheel forward and backwards until the thread comes free of the hook in the bobbin race. Follow this by cleaning any lint from the bobbin race of the sewing machine.
The last possibility is that the belt has failed. This belt transfers the energy from the motor to the needle bar. One source of the belt is http://www.sewingpartsonline.com/motor-belt-singer-007158xxl5.aspx . You can find YouTube videos on changing the belt. There are other parts that transfer the forces form the belt to the needle bar. However, I suggest you find a good sewing machine mechanic if any of these parts fail.
The manual has good pictures of the bobbin spindle on page 11 (page 18 of the PDF). Singer has the manual on their support page: http://www.singerco.com/support/instruction-manuals . The direct link to the manual is http://www.singerco.com/uploads/download/e06cb85928ace9753f1a7124f4a2df6168ffecf0.pdf .
I hope this helps.
Jul 28, 2017 | Singer Sewing Machines
My sewing machine is a Janome Magnolia 7330. The hand wheel will not manually turn backwards to raise or lower the needle. When sewing, the bobbin stitches are loose and looped.
I would find a local sewing machine sales and repair shop near you. You will need to have them look into this, it may be a timing issue or a broken or damaged part.
Feb 16, 2017 | Janome Sewing Machines
My sewing machine has stopped working, it was working ok , just a bit noisier than usual but now the needle wont move at all, even if i try to turn the wheel by hand
the machine may need oiling, check in your sewing machine manual to see about oiling it, it's also possible that the machine could have a damaged or broken part inside,,
Mar 17, 2016 | Singer Inspiration 4210 Mechanical Sewing...
Why doesn't belt move to sew?
retighten the hand wheel .
Mar 06, 2016 | Sewing Machines
I need a schematic of the interior of my machine so I can repair it. Motor turns on, fly wheel and bobbin mechanism works but needle and bobbin area don't.
Service manuals for sewing machines are available. Do an internet search. If the needle goes up and down when you manually turn the hand wheel you may simply have a belt problem (broken or off the pulley). If the needle doesn't move when the hand wheel turns, there's a major problem in the mechanism.
May 29, 2015 | Sewing Machines
Machine frozen
Switch the bobbin winder on and then off again, crisply, or turn the knob in the middle of the handwheel to tighten the clutch. If still no response, your machine may have a broken belt or be seized from lack of proper lubrication.
Dec 29, 2013 | Singer Sewing Machines
I have a brother XR-37. I was in the middle of
Did you find the broken bit of the needle ?
It may be jamming the bobbin case area and hook. Remove the needleplate and bobbin case and clean it all out then report back with progress.
Sep 01, 2009 | Sewing Machines
My machine won't spin the bobbin to thread it up on top. it sounds fine but it just won't spin it.
either the bobbin winder is seized or the rubber wheel has broken or come off. if it has seized you will need to dis-assemble it and clean out old gummed up oil and grease and re-assemble, or replace rubber wheel.
scott
Jul 18, 2009 | Kenmore Drop-In Bobbin 505S-21BH...
Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine Logo
163 people viewed this question
Top Kenmore Sewing Machines Experts
Irene Tulloch
Douglas Plant
Douglas Plant
tsalagi152
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
