I have a 2000 GMC Jimmy and the liftgate release is not working. Whenever I push the rear hatch button (located on the front console), I hear a sound but the gate is not unlocked. If I push the exterior button on the gate, it makes the same sound. How can I open the liftgate? The owner's manual mentions a manual release mechanism. However, I do not want to cut the carpet.
SOURCE: 2003 Saturn Vue rear liftgate won't open
The easy part is you just need the latch for the liftgate. The hard part is getting to it and opening the liftgate to replace the latch. You should be able to pull the liftgate trim off most of the way with the gate closed and try to manually actuate the latch to open the gate. You may have to go so far as breaking the latch from the inside to open the gate and then replace your latch.
SOURCE: How do you get liftgate open on a 97 Laredo with a broken lock?
You need to remove the panel from the liftgate and unlock and open it manually at the latch. It is not fun, but you can get the panel off with the hatch closed.
SOURCE: My 2003 LIncoln Navigator liftgate is not working.
check relay and fuses,make sure that automatic liftgate is on. You will have to to the command center and go through the defaults and make sure that the system is on. if you are not comfortable doing that, disconnect battery for approximate ten minutes, this will reset the system defaults.
