Expert
- Posted on Jun 01, 2010
Re: How do you remove interior door handle form 1993 Ford...
It's easy!
- Remove triangle-shaped plastic cover Fwd of door window - gently pry it off
- Remove screw from the plastic cover behind door open lever
- Remove door lock plunger. (unscrew)
- Remove screws down inside the door pull hand-hold area
- Look for other phillips screws - sometimes around the lower 1/2
- Pry hidden plastic hold down fasteners from around the edge - pull the panel away from the door and where you see it 'stuck' to the door, slide a pry tool, a stiff putty knife works well, up in that area and pop the fastener off.
- Lift door liner enough to get to the mirror power connector and unplug.
- For some model years, with door panel loose, you can access the bolts / screws that hold the interior trim piece in place and remove.
- Remove Mylar cover for access to 3 Mirror mount studs, speaker screws, door lock actuators, window motors, etc.
- Remove nuts, (hold the mirror up from outside) and remove mirror. (Feed electrical harness through door openings as required to facilitate removal.
- Reverse order for installation.
