Question about Kenmore HE2 Plus Front Load Washer
Kenmore HE2 wahser leaks water from the front door
Our Kenmore HE2 wahser leaks from just under the front door. The problem seems to be casued by a garmet that became caught/tangled in the door and pulled the rubber gasekt loose. The machine stopped and displayed a code F-25. After resetting the machine and reconnecting the rubber gasket (which did seem to be damaged) the machine still leaks. Any suggestions?
Posted by eric892 on
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: he2 front loading washing machine leak at the soap dispenser regi
well yea im aprentasing for plumbing. i have rain into these problems before yes it is clogged. its a pain but its fixable..
Posted on Jan 13, 2009
Anonymous
  • 619 Answers
SOURCE: Replacing the rubber gasket on Kenmore elite HE 3t
probably some rubberize installation are screw to the case or body/ you only need pollout are screw driver philips or flat .
Posted on Jan 10, 2008
myob247
Georgia B
  • 1342 Answers
SOURCE: leaking front gasket to Kenmore
Appliance Repair Clinic
Posted on Jun 01, 2008
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: chenging the rubber gasket attached to kenmore H2e front load washer
The following link provides you with step-by-step instructions on how to change the door bellow:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
This is not a difficult repair. Just follow the steps provided. If you have any questions, please let me know. I hope you find this information helpful.
Posted on Sep 02, 2008
Anonymous
SOURCE: HE4t kenmore washer rubber drum gasket not attatched.
Removed the top and Front reinstalled the counter balance. the rubber gasket has a 1" tear in it which I patched with a rubber tire patch for now. Two of the locking nuts for the leveling of the machine were loose it went out of level causing the machine to rock and probably caused the counter balance to loosen up. My daughters come in from collage and over load it on weekends which adds to the machines demise. All have been warned.
Posted on Jan 19, 2009
Leaking door
Either replace the rubber seal or the entire door
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Jan 19, 2014 | Kenmore HE2 Plus Front Load Washer
Leaking door
door must have a very small hole in it
Jun 12, 2013 | Kenmore HE2 Plus Front Load Washer
Water is leaking during the wash cycle. Nothing shut in the door. Been happening with the fuller loads.
try wiping or cleaning off the bottom part of the door,i've seen pieces of hair on the door and water leaks down the pieces of hair through the door,if that's clean then check for a hole in the rubber boot seal,most likely there's a hole in it
Feb 21, 2011 | Kenmore HE2 Plus Front Load Washer
Washer is leaking. If facing washer, water is on
probablly water pump or hose tilt machine to view where water is coming from
Jan 17, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore (HE2PLUS) front-loading washer leaking out the front door,,,,,,,,C. Pellecer
check the inner door seal it may be damaged that may be why it is leaking
Dec 16, 2009 | Kenmore HE2 Plus Front Load Washer
HE2 washer leaking water from bottom of door/seal during washing
Open the door so it is 90degrees from machine, see if it is upright. if not undo the door bolts slightly and re alighn door. Good luck and feel free to give feed back.
John
Sep 03, 2009 | Kenmore HE2 Plus Front Load Washer
Torn door seal on front loading washer
My husband used super glue on the tear and for now the washer is not leaking.
Mar 25, 2009 | Kenmore HE2 Plus Front Load Washer
F20 error on Kenmore HE2 front load for no reason
under top cover does it have flow meter? ck connection and resistence with ohmmeter, ck pressure sw.
Mar 14, 2009 | Kenmore Elite 45986 Front Load Washer
Sears Kenmore HE2 front load washer
there is a spring around door opening that holds bellows on remove it and pull back from inlet opening also possible if you use dry detergent a lump has become lodged in fill line working something from both ends may dislodge it
Nov 26, 2008 | Washing Machines
Kenmore HE2 Plus Front Load Washer Logo
Michael Thomas
Michael Thomas
Paul Carew
Lawrence Oravetz
