Question about LaCie Big Disk External USB 2.0 1TB Hard Drive
After replacing two new 1TB harddrives on my LaCie 2big Network it fails to work ,after a few second blinking blue and red te base shuts down . Contact Lacie and they told me that on the old drives was a firmware installt, but how can I install firmware if I can`t acces the drive
Posted by wuppie814 on
5 Related Answers
IB4G2008
Patrick Michaels
  • 3587 Answers
SOURCE: Lacie 1TB external hd won't mount!
check wires connecting them together first, ok?
then, turn off the LaCie, connect to your MacPro, and then turn on the drive..
that should show as a mounted drive.
need printer drivers update?
Posted on Mar 09, 2008
Anonymous
SOURCE: deference Lacie d2 Quadra1TB/Lacie big disk ?
It's all about the interfaces.
The Quadra has four interfaces: • eSATA • FW 400 • FW 800 • USB 2.0
The triple has all but the eSATA interface listed above.
For doing video work you want a big drive with a fast interface. If you have eSATA available then that's the fastest. If you don't then you're just as well off to go with the triple interface. The FW 800 would be the next fastest, then the USB 2.0, then the FW 400.
Because of the way that data is transferred I believe that when doing video work you would be best served by the FW 400 instead of the USB 2.0 even though the USB is faster I don't believe it is a full duplex communication so the FW 400 is actually better for video.
Posted on Apr 06, 2009
Robholmes
  • 69 Answers
SOURCE: Hi guys, accidentally pressed the big blue button
Sounds like you may have been unlucky in starting the reformatting software for the drive. Goto the following link to check out the documentation for the product:
http://www.lacie.com/download/manual/2big_Quadra_en.pdf
Posted on Mar 07, 2010
Anonymous
  • 3 Answers
SOURCE: lacie 1tb external hard drive into ps3 is not regconised
I have the same issue, however with my verbatim 500g its ok. i believe it is because the lacie is a desktop external and therefore is compatable with windows xp and 7 alone.
Verbatim is a "portable" external hard drive which makes it compatible with several different systems. I would suggest returning it, I just formatted my old verbatim harddrive and set up mediaasharing. Through my router. You can actually route the lacie harddrive by going to my computer and right click the icon. Next go to share with; advanced settings and allow all. Then when you turn your ps3 on search for media servers... I would suggest to google media server for ps3 to get it all seet up. GOOD LUCK
Posted on Sep 13, 2010
Anonymous
SOURCE: I have a 1TB LaCie 2Big Quadra. It has 2 500GB
I have the same problem too on my 2big form lacie . If I use 2x 1,5 tera disk in "fast mode" or in "big mode" my disk manager only shows 746 gigs available (it should be at least 2,5 terra).
If I use "safe mode" so my system can see 1,3 tera available, wich is normal for a raid mirror configuration.
I hope to find a solution quickly.
Posted on Jan 11, 2011
Lacie 2big 2tb drive LED flashing red what do I do?
You didn't provide details on what mode you were running or if this worked before and this is a sudden event. The manual doesn't appear to cover this situation of one blinking red light: https://www.lacie.com/download/manual/UM_2big_Quadra_EC_EN.pdf
but I found a YouTube video that may be helpful to you:
http://www.youtube.com/watch?v=V8KbtZYytC0
Sep 15, 2014 | LaCie "2BIG Quadra External Hard Drive - 2...
LaCie 2big Triple - I replaced one drive, but capacity is wrong
Most likely the problem you are encountering is due to the RAID mode the device is set in. Most RAID arrays utilize multiple drives of the same size, or with drives of differing size, they just use a portion of the largest that matches the smallest drive. When the device rebuilt the array it partitioned off a portion of the 4tb drive of the same size as the existing 500gb drive. If you want to use full capacity of both drives you would need to use JBOD mode, which just strings the disks together into a storage pool using all available space. This won't offer the data redundancy of RAID1 or speed boost of RAID0, but should allow using full space.
Backup any vital data before doing anything, then look for a switch on the back. Rather than RAID0 or 1 the options may be labelled Safe or Fast, but JBOD is usually still labelled JBOD, or sometimes Big. You can try just flipping the switch to JBOD and seeing if it rebuilds to use all space. If that doesn't work you may need to remove the 4tb drive, connect it to a different system and erase it to get rid of the 500gb partition, then with the Lacie set to JBOD reinstall the 4tb drive so it will add its full size to the array.
The safest option though would be to buy another 4tb drive, backup all data and install both 4tb drives with the device set to RAID1/Safe. You would only get 4tb of total storage, but it would mirror the data on both drives so if one fails the other will still have your data. With JBOD you won't have any auto-backup. If a drive fails the data on it will be lost.
Jan 21, 2014 | LaCie 2big Network (2-disk RAID) (301257U)...
I have problems configuring my new d2 Network 2 1.5 TB HD. Either using the LaCie Network Assistant or directly the IP address, I get a blank page with the message: Please wait while loading... and it...
Hello, I had similar problem with 2Big Network2 which was freezing the same way. I know the question is old but maybe someone will find this answer useful.
I solved the problem by updating the firmware. It may seem trivial but it took some time to figure out how to do it right.
My firmware was 1.3.7 and I was unable to easily get SSH access.
To upgrade the disk you have to
1. get it recognizable by Lacie Network Assistant. If you have a fixed IP it may not see the disk. To switch your device to DHCP assigned IP you have to reset it to factory settings (without losing data). Procedure from LaCie site works (http://manuals.lacie.com/en/manuals/d2-2big-5big-network2/reset)
  1. Make sure the product is turned OFF.
  2. Press and hold down the front button. Without releasing the front button, turn the product on by pressing the power switch on the rear of the product.
  3. Keep the front button pressed until the front LED becomes solid red, then release it. (The LED should become solid red about 10 seconds after you turn on the product.)
  4. The front LED will blink blue. When it becomes static blue, press the front button once within 5 seconds to confirm reset.
  5. If any of the steps are omitted, the product will boot normally without resetting.
2. you need the LaCie Network Assistant which you can download from here http://www.lacie.com/support/drivers/driver.htm?id=10138
I used 1.5.15 version for windows
3. Once you have the LNA installed it should recognize the disk. However if it doesn't start and says you are missing bonjour service just go to the installation directory and install bonjour.msi
4. At this point you should be able to start LNA which finds your drive. Now you need firmware (capsule file). You can't just load the newest firmware out there. Given fw version can be applied only to certain previous revisions. To check which version you need you have to check your current release. To get your current release open LNA and go to Configuration tab. The current system version is displayed in the bottom-left corner.
I updated mine to next release (from 1.3.7 to 2.0.5).
5. Now you should now to which release you should update. The question is where to get the firmware from if the LaCie support page (http://www.lacie.com/fi/support/drivers/driver.htm?id=10201) does not contain the one you need ? You can use and ftp service (it's not obvious).
Go to ftp://2bignetwork2-update.lacie.com/ (just put this address in files explorer address field) and login with 2bignetwork2 user and 2bignetwork2 password. Then browse for firmware.
6. now assuming you have successfully downloaded the firmware open LNA go to configuration tab and click "Update your NAS.." button. Authenticate with admin user and admin password then browse for the capsule file and begin updating
7. drive will need couple minutes to finish (blinking blue-red) then it will restart and when the light turns solid blue you should be able to get access to the web administration interface.
As other suggested - if you don't want to risk losing data get disk(s) (if in RAID0) and use some linux box or VM to backup data.
Jul 22, 2011 | LaCie d2 Network 2 NAS server (301505)...
I have a 1TB LaCie 2Big Quadra. It has 2 500GB and runs on RAID 1. I replaced both 500 GB LaCie drives with 1.5 TB LaCie drives, but my computer only recognizes the original 500 GB. I formatted both...
Dec 13, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
Product: LaCie 2big quadra ((Professional 2-Disk RAID. I have no back-up with the 2 disks, and this soon after purchase (August 2010). Serial number: 5102001839. Disk 2 does not work. At the front, light...
If the failed hard disk drive is replaced with the exact same capacity, RPM and make of hard drive, then the array can be rebuilt. Raid 0 cannot be rebuilt as each drive contains half of the data, If RAID 1 then can be rebuilt as data on each drive is an exact copy. However if combination of RAID 0 and RAID 1 then can be rebuilt. It's best really to handel this hands on, I recommend taking it to a computer technician especially if the information on it is important.
Thanking you
damnor01
Nov 13, 2010 | LaCie 2TB 2BIG QUADRA RAID EXT ESATA FW800...
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
Lacie 2 big does,nt boot
Hmmm, reseting worked on mine. Identical symptoms except light stayed blue, not red. Unable to power down.
Before trying to get the drive working I got the data off using the procedure in the second post of this thread:
http://www.linuxforums.org/forum/peripherals-hardware/126831-reseting-lacie-2big-network.html
You need a linux system running. Maybe a live cd will do. I installed on an old IDE drive I had.
I then rest the decive using this procedure from Lacie and my drive is working again. Worthless though, because I can't trust it.
The procedure below will reset the 2Big Network to factory settings:
IMPORTANT NOTE: Following the procedure below can ERASE ALL DATA on the drive. Prior to following these directions, verify important data is stored securely on a different storage device.
Switch the drive OFF. Once it has shut down, ensure the power switch remains in the OFF position.
If the drive is in the SAFE mode, move the RAID switch to the BIG mode.
PRESS AND HOLD the button on the front. MOVE the power switch to the ON position. The light on the front of the drive will start blinking.
Once the light stops blinking, RELEASE the front button.
When released, it will begin BLINKING AGAIN. When it stops, PRESS AND HOLD the front button. The light will begin to blink again.
When the light stops blinking, RELEASE the button. The drive is now resetting itself. Switch the RAID selector back to SAFE if desired.
To restore data if it was lost during the process, recreate the shares and users on the unit prior to the reset. Any firmware updates applied will need to be applied again.
Sep 02, 2009 | LaCie 2big Network (2-disk RAID) (301257U)...
Exactly same problem
check your network for conflicts, check power supply, fan and nic card, if your sure it's not the the drives inside the drive case, I have had 4 of these fail on me @work with different issues power supply nic card and both drives 4 units did the same thing and they were under warranty so when I got it back, I sold them and bought The Seagate BlackArmor NAS 420. no problems with them as of yet. Lacie get hot and components get hot and fail because there is not enough air flow I think.
Aug 13, 2009 | LaCie 2big Network (2-disk RAID) (301257U)...
Lacie 2big Triple 2T - Raid 1 LED's blinking
Solved! After 17 hours of blinking, the status of the 3 leds is now to fixed blue. You just have to be patient...
Note that I had only put 1GB of data on the drive. I expect that the resynchronization time is not proportionnal to the amount of data on the disk!
Jun 07, 2008 | LaCie 1 TB 2big Spare Drive 301307 SATA...
Open Questions:
LaCie Big Disk External USB 2.0 1TB Hard Drive Logo
228 people viewed this question
Top LaCie Computers & Internet Experts
ChinthakaJ
ChinthakaJ
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
