SOURCE: I desparately need some assembly instructions for my Barbie tent.
Mattel products, including Hot Wheels, Barbie and Polly Pocket:
In the US and Canada: 800-524-8697
SOURCE: Wenger Swiss Military Watch: small set-time handle fell off.
That small gizmo is called CROWN or WINDING CROWN. It is not possible to obtain it online, so, you have to shop around for it. Find your nearest watchmakers shop and ask for replacement. You may need stem as well.
Rate, please.
SOURCE: We just purchased a used '99 Starcraft Field &
I had exact same problem on my 93 popup. I finally figured it out. First, the poles with the plastic rings slide into the poles with the metal rings. These are the vertical support poles. Next, the poles w/ plastic nipples slide into the other poles with rubber ends. When put together the poles with the nipples should be spring loaded. These spring loaded poles rest against the top of the camper and the nipples are inserted into the 3 holes of the pole that go across the front of the awning giving you rafter support. The tension from the spring should keep the pole in place against the side of the camper. The first 3 poles with the plastic rings go from the ground to the front awning pole where the nipples can slide through the plastic ring and then into the awning pole. The vertical poles can be adjusted for height by sliding them up or down and then twisting them like a screw to tighten them up and keep them in place. 2 of my 3 vertical poles will not lock when I twist them so I have to get tricky with them. The metal rings, which should now be at the ground, are there so that you can stake it down under windy conditions. I hope this wasn't too confusing but I beleive it will help you. Good luck!!!
SOURCE: square tent with 2 types gazebo poles, varenda, 2 side windows
the 2 longest of the poles go in an x over the center of the tent and the 2 shorter ones go arch to the sides. http://www.wenzelco.com/details.aspx?NavID=412
shows a picture very similar to your tent. If you go to image 2 it shows it with out the fly. now if you got 2 sets of 4 poles, 2 long and 2 short, and one set is all aluminum, then I would go with the aluminum set. It is less likely to collapse in high winds.
SOURCE: I have a Thermos
I have one of these tents, here is how you operate it. When you pull down to set the tent, pull down on the larger fatter end. When releasing, pull down on the skinny side. I use the canvas bag to pull it down. That makes it easier on the hand. Or use work gloves.
Good luck
J
