Question about JVC RC-EX25 Radio/Cassette/CD Boombox
I have a JVC RC-770C (stereo, radio, cassette, recorder) And it works perfectly until I try and play my cassette tapes. when I play, rewind or fast forward the tapes it gives me a strong buzzing/humming/static noise. I can hear the tapes (they're all in great condition) if i listen carefully but the static noise is too distracting. how do I fix this?
SOURCE: Tape is stuck in VCR- Fast rewind and forward
It may need to be cleaned. Mechanical problems are one of the big problems with VCRs they use alot of mechanical moving parts and play for so long they fail. Plastic parts dont help much either. The pinch roller takes up the slack and is usualy the part that fails first because it constantly runs along the tape and builds a coating on the rubber so it doesnt grip the tape and pull it back into the cassette. If its not pulling the tape back in then it hangs up inside and you cant get the tape out. Fastforward uses the reels to pull the tape not so much the roller. Try and stop 2 times then fast forward then eject the tape. Try and eject the tape while its fastforwarding so it doesnt do anything else. Sometimes machines will unload after its been in fastforwad a while then it will eject. You will hear a change in the sound when it unloads, you can hear the mechanical arms move the tape in and out of the cassette. Thats when you eject it. You cant really clean it till you get the tape out. YOu can clean the pinch roller with fingernail polish or paint remover. It is a wheel inside it looks like a black tire. It pinches the tape against the capstan arm this is why it developes a film or a shine on the rubber making it slip.
Posted on Apr 04, 2006
SOURCE: Tape get stuck when I playback after fast forward the tape
Yes, that is a possibility. Also check the mechanism which activates the brakes- is something sticking or broken? A dried or sticky grease can cause the brake mech. to hang up. A broken or cracked lever or slide piece could be your problem too. Late VCRs of the last 10+ years are rather breakable, unlike the older ones which were often built like tanks, comparatively speaking.
Posted on Sep 26, 2007
SOURCE: CD Changer & Tape Deck
Check for dirt on CD laser lenses. Also transmission on tape player.
Posted on Oct 03, 2007
SOURCE: cassette player will not work
common fault on the JVC tape decks is the belt stretch and then it does a clicking sound its trying to pick up the audio heads. changing the belt is quite hard if you have`nt done it before.
craig:)
Posted on Jan 20, 2008
SOURCE: How Do I Preset Radio Stations ?
Looked online for a manual for unit and found them with a wide price range.Check on the web or contact JVC.Make sure you have the correct model number.
Posted on Sep 23, 2009
