2000 Honda prelude bogs out when I press accelerator quickly. If I flutter the pedal it causes it to backfire and sputter and eventually die out. It starts fine and runs at idle fine, just acceleration causes rough running and any load on the engine causes it to sputter. I changed the fuel filter and PCV. Wondering if injectors need to be changed??
What should I do if once I turn on my Ac my idle drops as if it's gonna die, and .... to a complete stop the rpms start going up and the car accelerates on its own. ... Honda Accord LX, and my Honda just started sputtering in idle. check engine .... My cousin replaced my radiator on my 90 civic and since then my temp gauge is ...
Jun 11, 2010 - 1990 Honda Accord Ex F22 209000 miles, recent alternator change When I ... When I take off from a stoplight I get a little hesitation/bogging/sputteringfeeling until about 2,000 RPM then ... My 1999 Accord had a similar problem (F18B2engine). ... It only lasted a second or so before it would actually rev up.
you need a tune up new wires plugs car and rotor and do the air and fuel filter to. after it will be like a new car and the fuel savings will pay for the parts
Sounds like the timing open the distributor and in there is a relector,is there alot of corrosion? This reluctor has a tendency to shift out of position causing the vehicle timing to retar,Another area to inspect is the MAP (manifold air pressure) .This sensor monitor engine load according to vacuum when this goes out you cant accelerate the vehicle and it sputters as the vehicle tries to accelerate,you need to check that the vacuum hose has not come off,or just failed
Have it checked with a computer diagnostics. It sounds like it could be a bad sensor, quite possibly your oxygen sensor. A bad sensor could cause the computer to think your engine needs more fuel.
