Master
- Posted on May 26, 2010
Re: Sounds like fan belt noise but, the fan belt looks...
If your belts are in good shape and tension is proper, you should take off the belts and srin each pulley or tensioner that turns with the belt. I think that you will find that a bearing is going bad. Try to do this when the engine is cold for that will usually make the noise more pronounced.
