Try opening the file in Photoshop, copy the image to a new document and save. It might solve your problem.
ps
There are lots of different .jpg standards, other files like .tif are more stable.
You have to make sure your telling your scanner what your scanning. Most often it defaults as a mixed image meaning text and image. You have to tell it to scan text only and then see what options you have. If this doesnt help then do as i stated above choosing text only and save to computer as a microsoft word document. Now make sure you have latest Acrobat reader 9.0 installed and now with your word document open in top left File button there should be an option to convert to pdf format. I hope this helps and good luck
Change the file format its saving in. different formats have different compression rations. Jpg images are smaller than bmp images. simply by changing it to jpg it will be 20 times smaller. To do this when click save and the save image box appers, in the format type select jpg or gif or what ever is avilable. Play around to see what gives you the smallest size. You can also use software like Photoshop, paint, and other image editors to change the format its being saved in.
I'm using an MP780. Usually when I scan an image to jpeg I press START, CANON, SCANGEAR STARTER. This open a window to ScanGear MP. Since I use the Advance Tab I can set the DPI and whatever outputs. The DPI rsolution will determine the size of the file also. When it is finished scanning it goes to the next window which has Save As Type and Save Scanned Image to. Save As Type is where you can choose JPG or TIFF or BMP. Hope this helps.
Hi if u r not getting the jpeg option do one thing open the cd content, go to setup folder in which u ll see trayapp folder open that one there u ll find trayapp.msi right click on it and click on repair ... then reboot the pc and try to scan ... it shud work else get back, i ll give u the other options
images are saved in the following format.
Econ / Standard / Fine: JPEG (.jpg)
Super Fine: TIFF (.tif)
RAW: RAW (.mrw)
Movie: Motion JPEG (.mov)
Audio recording: WAVE (.wav)
Symbols in brackets represent the file extension.
Thumbnail data (.thm) is also saved for TIFF, Movie and RAW files.
