Avery DesignPro 2000 for PC Logo
Posted on May 25, 2010
Design pro , changed my monitor and now all cd labels are oval, how to adjust from 4:3 to 16:9 have downloaded latest design pro 5 problem still the same.
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on May 25, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2120
Points
7
Draw a flowchart to print the product of the first 10 even numbers
How do you convert a .zdp file to a .jpg file
It doesn't look like you can export directly from Avery Design Pro to JPG, but you can download a free copy of Design Pro Limited from Avery's site. Then, you can load you .zdp file and use alt-printscreen to get an image of the Design Pro window. Then, paste the image into Photoshop or a similar program and crop out everything but the label.
Avery Design Pro Limited (free download) at http://www.avery.com/us/Main?action=soft...
How to print cd covers with HP Photosmart Essential 3 5 i have microsoft office 2010 beta and open office 3.1 installed and some avery standard #8931-face-cd labels nd can not figure out where the tools...
hi Justchuck69.
You can use the software that came with your HP Photosmart all-in-one printer to create CD covers and then print them on the discs. For this to work, the CD must be printable, and you shouldn't use CDs that have their manufacturer, size and speed already printed on them. You must use the latest HP software to create and print the covers. If you can't find the installation disc that came with your printer, download the latest version of the software from HP's Support website.
1 Launch the HP Solution Center that was installed on your computer when you installed the HPsoftware.
2 Click the "View Library" button to open the photo library and then select the folder that contains the images you want to use for your CD cover from the left pane. Click the "Add This Folder" to add the folder to the library. You can only use photos from the library to create the CD cover.
3 Click the "Back" arrow near the top of the window to return to the Welcome screen.
4 Click the "Create" button, choose "Disc Labels," and then click either "Standard CD" if you want to print on a standard CD or "Mini CD" if you want to print on a mini CD. Click "Choose This Format."
5 Choose a design from the list of designs, and then click the "Choose This Design" button.
6 Select the photo or photos you want to print on your CD, and then click the "Add These Photos" button.
7 Use the controls in the Edit Your Disc Label section to zoom, rotate and reposition the photo. Click the text boxes and type or paste some text, if you want to add text to the label. Click "Create" when you're satisfied with the result.
8 Select the HP Photosmart printer from the "Printer" drop-down box, and then ensure the "Standard Sizes" option is selected.
9 Click the "Print" button when you're ready to print the cover on the CD. The "Open CD/DVD Tray" message is displayed on the printer's LCD.
10 Pull the CD/DVD tab below the main tray to remove the CD holder, and then place the disc on the ring of the CD holder with its print-side up. Gently press on the CD until it snaps into place.
11 Lower the CD/DVD tray located just below the control panel, and then insert the CD holder into the tray. The printer starts printing as soon as the white lines on the tray and holder match up.
12 Wait until the printing process is complete, remove the CD holder from the tray, let the ink on the CD dry for a few minutes, and then remove the disc from the holder.
13 Close the CD/DVD tray, and then insert the CD holder back into the storage space.
Tips
  • checkPhoto Creations, the latest software from HP, does not support printing CD labels. HP Photosmart Essential is available for download from HP's FTP website (link in Resources).
  • checkThe back of the HP all-in-one printer must be at least three inches away from the wall or other objects.
  • checkIf you use a small CD, don't forget to flip the holder ring over the disc before you snap the CD holder into place.
  • checkYou can add additional folders to HP Photosmart Essential if you can't find the photos you want to print on the CD.
  • checkYou can bold or italicize the text when you type it, but you can't choose a different font or change the size of the text.
  • checkAlternatively, you can use a free third-party utility to create the CD cover and then print it on the disc.
Warnings
  • closeDon't turn off or unplug the printer from the computer while it prints the CD cover.
  • closeInformation in this article applies to HP Photosmart Essential 3.5. Procedures may vary slightly or significantly with other versions or products.
Ads
CD/DVD Label Software
Download free software to create CD and DVD labels on Windows or a Mac
NCH Software
Start Download
Microsoft™ 64/32 Bit Driver Download Driver Support™ Free Scan
Driver Support.
plus you could read up some more at this link if the above does not work for you.
How to print cd covers with HP Photosmart Essential 3 5 Google Search
Cd stomper pro 3.x manual for cd-r labels for Windows
find your manual from these site
1) www.atpm.com/5.10/cdstomper.shtml
2)
www.getprice.com.au/Avery-CD-R-Stomper-Matte-Labels-Pk-100-Gpnc_576--40034978.htm
3) www.dealtime.com/xDN-office_supplies--cd_and_dvd_labels
Will my avery design pro work with Windows Vista?
It should but check the Avery website for any downloads for Vista if you have any problems. Let me know if you have any problems.
Thx
8helpful
I need a manual on my stamina r360 recumbent bike how to clear the settings on the in touch monitor
If this is the same Stamina R360 as I have, you just hold down the orange oval button (labeled: MODE) until you hear a beep. This resets the readings.
1helpful
Can I print a cd on my canon mp510 printer?
You need to download a CD cover creator software. If you also want to print your own CD label stickers (round ones for the disk) you will need also to buy CD avery templates.
Here is the software:
Download Super CD Cover Maker v2.0.0
Cd Cover Label Software Freeware
CD Cover Designer 2.5 {freeware} at Damn Printer
Free CD/DVD Covers Software Downloads
Cd covers Free Download
Easy CD and DVD Cover Creator and Label Maker.
Here instead you can buy cd labels:
Avery Labels, buy Avery office products, Avery CD Labels
1helpful
2answers
Avery DesignPro Error while initialising
Reinstalling and restarting won't solve the problem. For some reason Avery design pro limited attaches it self to windows user account. You can create another windows user account and run the program and it will work. When you start the program in the new windows user account it will ask you for your name "Author Name".
Top Avery Computers & Internet Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Are you an Avery Computer and Internet Expert? Answer questions, earn points and help others
