Frigidaire FDL50R1 Dehumidifier Logo
Posted on May 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The dehumidifier runs but will not draw moisture from the room
Anonymous
Level 3:
  • Frigidaire Master 43,501 Answers
  • Posted on May 25, 2010
Anonymous
Frigidaire Master
Level 3:
Answers
43501
Questions
0
Helped
10843241
Points
101584
There are many reasons for a dehumidifierthe dehumidifier runs but will not draw moisture - 2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehuthe dehumidifier runs but will not draw moisture - 2_bing.gifmg src="/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" />.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
2helpful
2answers
Does not collect water in bucket but runs all the time
Does it have a filter?
http://whirlpool.custhelp.com/app/answers/detail/a_id/953
also:
It may be that the humidity level or temperature in the room where your dehumidifier is located is too low.
When the outdoor temperature is below 50 F, the indoor air will be dry even when the air inside is warm, therefore when it's cold outside the dehumidifier may collect little or no water.
Air conditioners will also remove moisture from the room, even if it's hot and humid outside, resulting in little or no moisture collecting in the dehumidifier bucket.
Some dehumidifiers have a deicer which turns off the compressor but keeps the fan running. When the compressor is off, moisture is not removed from the air. The deicer turns off the compressor when the room temperature is cold.
Some dehumidifiers do not have a deicer. If the room temperature is low enough, ice may form on the evaporator coil. The ice prevents the dehumidifier from removing and collecting water. If ice forms on coils, unplug dehumidifier until ice melts and room temperature rises."
tip
Dehumidifier VS. Air conditioner
A dehumidifier is basically the same thing as an air conditioner but both coils (condenser and evaporator) are in the same unit meaning a dehumidifier exhaust warm air in the same room it is in. running a dehumidifier would make an air conditioner run more because of the warm exhaust, when you run an air conditioner it acts like a dehumidifier and dries the air. As far as saving energy it all depends on the size of the AC and dehumidifier and the size of the room. If you want warm dry air, use a dehumidifier; if you want cool dry air run the AC but not both.
How do all these parts fit together to pull moisture from the air? It's fairly simple, but very effective:
  1. A fan collects air from the surrounding area and pulls it into the dehumidifier.
  2. As the air passes through, it comes into contact with the dehumidifier's cooled coils. These coils use condensation to pull moisture from the air. The collected moisture remains on the coils and drips into the dehumidifier's reservoir.
  3. The dehumidifier reheats the air and exhausts it back into the room.
A dehumidifier usually has a removable plastic bucket for are reservoir; most buckets also have a place where you can hook up a hose so the collected water can drain straight into a floor drain or pump. This frees you from having to remember to dump out the water. But don't worry too much about the reservoir overflowing -- most dehumidifiers also have an automatic shut-off. If you're using a dehumidifier in extremely moist conditions,however, or if you need to keep your dehumidifier on all the time, you should look into a unit with a built-in condensate pump, which regularly pumps water out of the unit's reservoir rather than simply relying on gravity to empty it as a hose does.
on May 18, 2010 • Dehumidifiers
Plug it in turn it on and nothing in the bucket after several hours
Hi, Mindy! The following is an overall review of what causes the problem you listed.
If the room air is less than the set air, then there is no water in the bucket, because there is almost no humidity in the air. If it is winter, there is likely not enough humidity in the air to have water collect in the bucket. A dehumidifier will only pick up humidity out of warm air. If you are running a dehumidifier in your basement in the winter, the room may be damp, but too cold for the dehumidifier to pull out the humidity. Try running the unit in the bathroom after having a hot shower without the bathroom fan on. If working correctly the unit should draw water. In addition, if you set the humidity level you want to maintain higher the actual humidity level in the house or room, it won't pickup and collect any moisture. The fans on most of the dehumidifiers on the market today run almost constantly. They do this, so that the room air is always moving and if humidity is detected, it will extract it.
Hope this helps you understand how dehumidifiers function and what you can expect from them under given circumstances,. In fact, there may not be anything mechanically wrong with yours. But, to make sure, do what is suggested above to test the unit.
1helpful
2answers
Dehumdifier not collecting water.
The filter (on some models) may be dirty or clogged. If so, clean the filter. For instructions on cleaning the filter.
I hope this help to solve, if this answer solve it, remember to rate it. Good luck.
Freesing up and bucket not filling
The coils you see on the back of your dehumidifier are the evaporator. When the unit runs, the coils get very cold. As the fan draws the room air over the coils, the humidity in the air condenses out of the air onto the cold coils. But, if the temperature of the air the fan draws over the coils is too cool, the humidity that condenses out of the air freezes on the coils. To remedy this problem, you can try any of these: Warm up the room the dehumidifier is in. Put the dehumidifier on a sturdy table (the room air is coolest near the ground). Turn the unit off until the room warms up.
Take care.
HOW TO USE
follow the instructions below on how to use your dehumidifier:
Prepare the room for the dehumidifier by vacuuming, dusting and cleaning the room. Be especially careful to have all mold removed prior to using the dehumidifier.
Plug in the dehumidifier into a grounded outlet.
Set the dehumidifier to high in order to remove excess moisture from the room.
Wait for the dehumidifier to run several cycles, removing all undesired moisture from the air. This may take days or even weeks in especially damp rooms.
Adjust the setting of the dehumidifier when the air has reached your desired comfort level. Make the setting one that will maintain the current conditions.
Good luck.
My dehumidifier ices up. It will not remove moisture when it ices up. What can I do and is it under warranty?
Take care.
3helpful
It runs but doesn't collect water. Had the hose
try adding heat to the room it needs heat to draw out moisture and close any doors or windows to help isolate the area desired. just obvious tips to try if not already done so
2helpful
What could be wrong with my dehumidifier it runs but doesn't draw moisture anymore
does the air feel humid? could be the humidity level dropped and there isn't any moisture in the air. the air passing over the evaporator coil needs to be laden with moisture for the dehumidifier to work.
Top Frigidaire Dehumidifiers Experts
john h
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
