Question about Philips HTS-3555 System
How do i connect a xbox 360 to a philips hts 3555 and hd tv?
How do i connect a xbox 360 to a philips hts 3555 and hd tv so i have surround sound for everything?
Posted by danny_farmer on
Anonymous
    New Friend:
Connect audio out cables (L and R) from HDTV to far left audio input at back of hts 3555. Then connect HDMI output from XBOX360 to HDMI input slot on TV. Setup XBOX 360 for audio through HDMI turn TV off and then on and all should be good. It worked for me.
Posted on Jul 22, 2010
Cannot get surround sound to work with Philips hts3106/f7 andonic tcp50g25. It works fine for Blue ray via the hdmi out of philips dvd/receiver, but not for xbox or cable etc (only works in stereo).
i have the same system. all you have to do is when you connect your xbox 360, press the surround button on the remote and then use the arrow buttons to change it to dolby music pro2 or multi channel audio. same goes with any device you connect. hope it helps. In my case the xbox is connected to the Tv via HDMI and bluray player is connected to xbox via compoent cable
Nov 26, 2011 | Philips Audio Players & Recorders
Not sure how to connect other devices
Unfortunately, the Westinghouse monitor has a bunch of inputs available, but completely lacks the audio output connection you need that would make life simple. Your Philips HTS only a single auxiliary audio input, but it does offer video and audio output connections to a monitor.
About the only solution I see available is to buy an A/V selector switch (available from Radio Shack and probably stores like Best Buy). Run the audio connections from the HD receiver and XBox through it, and send the output from the selector switch to the auxiliary audio input on the HTS6500. (You could use RCA Y-adapters to connect the audio to the monitor as well as to the selector switch if you really want to.) Send the video from these sources directly to the monitor.
You would need to select the source on the monitor, A/V switch and HTS to get the result you want, but it would be workable. (Now, why didn't Westinghouse simply include a set of audio output jacks with all those sources available?)
If this solution has gotten you going, please take a moment to rate it. And thanks for asking here!
Feb 25, 2009 | Philips HTS-6500/37 System
Plays cds not dvds
Hai,
This is is due the lense and motor section problem, to resolve this issue you need to replace the lense and motor set.
Feb 11, 2009 | Philips HTS-3555 System
DVD suround ystem
Sir,
This is due the the DVD issue, so please check the dvd audio support as well 5.1 channel enabled on your player to get the surround sound.
Please keep in mind that if the DVD supports 5.1 channel then only you can here the surround effect.
Aug 10, 2008 | Philips HTS-3555 System
Unlock HTS 3555
Press "Door Open"
- after the door opens perform the following sequence with the remote control:
Press STOP-7-3-4-4-6-6
a Region settings page will be displayed showing the current region on the TV (usually the default is region 1), using the remote control select the region number by pressing the number on the remote (select region 0 for region free) and press OK.
May 05, 2008 | Philips HTS-3555 System
HTS-GS1 Surround Sound System cannot be utilized for tv.
Check Your TV audio setup,many TV makers out there would like you to turn off the tv speakers in order to use the external speakers.
Joe
Feb 03, 2008 | Pioneer HTS-GS1 Theater System
Television surround sound problem
well u have to use tv rca out to a input on this system ok then select input 1 aux in ect on sound system ok
Feb 02, 2008 | Pioneer HTS-GS1 Theater System
Philips lx3700d
This HTS can't read opticals
Jan 14, 2008 | Philips LX3700D System
WIRE ELIMNATION
For the TV:
There are a few possibilities.
1)You can connect a red and white AV cable (or the red and white portion of a red, white and yellow cable) from the TV Audio OUTPUT to the "Audio In/TV" portion of the HTS (NOTE: Many TV's do not have an Audio OUTPUT).
2)You can connect a red and white AV cable (or the red and white portion of a red, white and yellow cable) from the Audio OUTPUT of your cable or satellite box to the "Audio In/TV" portion of the HTS.
Note: Using a red and white cable may not give you sound on all 5 speakers.
3)Get a digital audio or SPDIF cable and run it from the TV, Cable or Satellite Box's Digital Audio OUT to the "DIGITAL IN" of the HTS. This will give you the best sound quality. When using this (or any of the other) type of connection, press SURR until you get sound from all 5 speakers.
For the Xbox, try hooking a red/white audio cable from the Xbox into the Audio IN/AUX on the back of the HTS, and then switching the source on the home theater to AUX.
Also, the manual can be obtained from www.usasupport.philips.com
-Tha Mp3 Doctor
Jan 06, 2008 | Philips HTS-6500/37 System
No sound from tv to surrond sound.
First, press the SURR button to see if you can get sound out of more than 2 speakers, then:
-Tha Mp3 Doctor
Dec 28, 2007 | Philips HTS-3555 System
Philips HTS-3555 System Logo
965 people viewed this question
Top Philips Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
aliasger yq
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
