Question about Sharp AL 1631 Copier
I have a sharp al-1631 flashing l1 code what is this and how do i fix it.
Posted by vytechsigns on
abbas rezazadeh
  • 328 Answers
Your scan unit cannot move. check if you use longer screw for top glass
Posted on May 25, 2010
AL-1631 is flashing "H". How do I fix this which appears to be heat related.
the h means that your fuser needs to be replaced. it might be fixable by changing the thermal fuse but most of the time the whole fuser needs to be replaced
Sep 28, 2014 | Sharp AL 100DR Laser Toner Drum Works for...
We are trying to make copies and there was a light flashing and it said 1L and we are unable to make copies the copier has been reset and the toner and drum have been replaced already and i have also...
I have a tip posted here at Fixya that covers the Sharp AL Series Copier L1 code.
Here is the link:
http://www.fixya.com/support/r4378514-sharp_al_series_copier_l1_l_1_error_code
If it helps you with your L1 code then please return here and provide some feedback.
Thanks,
WheatlandServices
Dec 16, 2010 | Sharp AL 1631 Copier
ESTÁ DANDO MENSAGEM DE ERRO L1 NA COPIADORA AL-1631
L1 signal means your copier exproser lamp carraige is not home position.Clean all surface and sensor hten solve it
with the best luck
Aug 03, 2010 | Sharp AL 1631 Copier
SHARP COPY MACHINE AL 1631 FLASHES A L1 ERROR
Most likely when removing a copy someone hit the scan lock on the front of the machine.
Look on the front , bottom side of the scanner where the paper comes out. You will see a latch that is used for shipping the machine that is more than likely locked.
Thats what causes an L1 90 percent of the time. Just slide it to the unlocked position or take a small screw driver and remove it and throw it away. You can put a piece of tape over the opening to keep dust and moisture out
Jul 15, 2010 | Sharp AL 1631 Copier
Error Message
You have a bad Laser Unit
Jun 02, 2010 | Sharp AL 1631 Copier
Sharp AL 1631 is flashing 1 L. What does that
Hi:
This might refer to your scanner assy being locked. The scanner assy is the unit under the glass that scans your document prior to copying it. Look inside the cavity where you pick up your completed copies. Look at the upper left corner and see if there is a knob there. If there is, make sure it is in the completely unlocked position.
Andrew
Aug 09, 2009 | Sharp AL 1631 Copier
SHARP AL 1631 copier is flashing L1 and will not print
Ensure the carriage lock is off, if you have cycled the lock and restarted and still have the problem you may have a fault with the scan carriage.
Jul 06, 2009 | Sharp AL 1631 Copier
Flashing L1 Display
clean the stripe band unther the glass
Dec 26, 2007 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
202 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
