Posted on May 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Borderless Printing Doesn't Happen
Page setup is set to borderless in both Publisher & in HP J4550 properties. But when printed the picture has an approx 1'' border
steve morris
Level 3:
  • Master 1,675 Answers
  • Posted on May 24, 2010
steve morris
Master
Level 3:
Answers
1675
Questions
0
Helped
653495
Points
5484
Hi as you have set border less printing in publisher and on printer, have you adjusted the layout guides? on the blank page go to arrange, then to layout guides, adjust the numbers to atleast 0.25 (lowest it will go) and save then try printing, the but remember, hp still has a border due to the print heads position they do not travel over the print area like some printers do, you will always get a small white line no matter what...hope this helps
When I copy to photo paper it reduces automatically, why
Print on special and custom-sized media
To print on special or custom-sized media (Windows)
1. Load the appropriate media. For more information, see Load media.
2. With a document open, click Print on the File menu, and then click Setup,
Properties, or Preferences.
3. Click the Paper/Features tab.
4. Select the media size from the Size is drop-down list.
To set a custom media size:
a. Click the Custom button.
b. Type a name for the new custom size.
c. In the Width and Height boxes, type the dimensions, and then click Save.
d. Click OK twice to close the properties or preferences dialog box. Open the
dialog box again.
e. Select the new custom size.
5. To select the media type:
a. Click More in the Type is drop-down list.
b. Click the desired media type, and then click OK.
6. Select the media source from the Source is drop-down list.
7. Change any other settings, and then click OK.
8. Print your document.
To print on special or custom-sized media (Mac OS)
2. On the File menu, click Page Setup.
Chapter 2
28 Use the device
3. Verify that the correct printer is selected.
4. Select the media size.
5. To set a custom media size:
a. Click Manage Custom Sizes in the Paper Size pull-down menu.
b. Click New and type a name for the size in the Paper Size Name box.
c. In the Width and Height boxes, type the dimensions and set the margins, if
desired.
d. Click Done or OK, and then click Save.
6. On the File menu, click Page Setup, and then select the new custom size.
7. Click OK.
8. On the File menu, click Print.
9. Open the Paper Handling panel.
10. Under Destination Paper Size, click the Scale to fit paper size button, and then
select the customized paper size.
11. Change any other desired settings, and then click OK or Print.
Print borderless
Borderless printing lets you print to the edges of certain media types and a range of
standard media sizes.
NOTE: Open the file in a software application and assign the image size. Make
sure the size corresponds to the media size on which you are printing the image.
You can also gain access to this feature from the Printing Shortcuts tab. Open
the printer driver, select the Printing Shortcuts tab, and select the printing
shortcut for this print job drop-down list.
NOTE: Borderless printing is not supported on plain media.
To print a borderless document (Windows)
2. Open the file that you want to print.
3. From the application, open the print driver:
a. Click File, and then click Print.
b. Click Properties or Setup.
4. Click the Paper/Quality tab.
5. Select the media size from the Size is drop-down list.
6. Select the Borderless Printing check box.
7. Select the media source from the Source is drop-down list.
8. Select the media type from the Type is drop-down list.
Print borderless 29
9. If you are printing photos, select Best from the Print Quality drop-down list.
Alternatively, select Maximum dpi, which provides up to 4800 x 1200 optimized
dpi* for optimum print quality.
*Up to 4800 x 1200 optimized dpi for color printing and 1200 input dpi. This setting
might temporarily use a large amount of hard disk space (400 MB or more) and will
print more slowly.
10. Change any other print settings, and then click OK.
11. Print the document.
12. If you printed on photo media with a tear-off tab, remove the tab to make the
document completely borderless.
Change settings from an application for current jobs (Windows)
To change the settings
1. Open the document that you want to print.
2. On the File menu, click Print, and then click Setup, Properties, or Preferences.
(Specific options may vary depending on the application that you are using.)
3. Change the settings that you want, and then click OK, Print, or a similar command.
Change default settings for all future jobs (Windows)
1. Click Start, point to Settings, and then click Printers or Printers and Faxes.
- Or -
Click Start, click Control Panel, and then double-click Printers.
2. Right-click the printer icon, and then click Properties, Document Defaults, or
Printing Preferences.
3. Change the settings that you want, and then click OK.
9. If you are printing photos, select Best from the Quality drop-down list.
dpi*.
print more slowly.
10. Select the media source. If you are printing on thick or photo media, select the
manual feed option.
11. Change any other print settings, and then click Print.
5answers
Blank page feeding during print job
Please adjust paper size in printer properties.
Teardrop shaped light flashing on hp 5650
Hello Sgaetjens,
The tear drop shape LED is called the print catridge LED indicator. If you do see this light flashing it means that there is an issue with one or both of the cartridges. This issue can occur for the following reasons:
  • One or both cartridges might be incompatible with the product.
  • One or both cartridges might be improperly inserted.
  • The borderless printing settings require adjustments.
For the first,two I suggest that you verify that it is indeed HP original cartridge and not just replacement ones that you can purchase anywhere. Remove and reseat the ink cartridges carefully. With regards to borderless printing, go to Control Panel and then Printers and open up your HP Printer and then check the properties and defaults. Normally it is under Printing Shortcuts where you could find Borderless Printing.
1helpful
When using canon pro 9000 with photoshop on a MAC Snow Leopard computer, I cannot print borderless pictures. How can I fix this problem
Preserve your memories forever with borderless printed photographs--while saving money and time by printing from the comfort of your own home. Some printers do not have the option of printing borderless prints, so make sure your printer supports borderless printing before beginning this project.
  • Download your digital photo to your computer from a digital cameramag-glass_10x10.gif, email or the Internet. Save the photo to your hard drive to a folder that you can find later such as "Pictures."
  • Step 2Open your digital photo in a photo-viewing software. Click "Print" from your menu. Go to your printer properties to change your printer's "Page Setup." Access "Properties" through the "Preferences" or "Options" link in your "Print" dialog box. Many software programs have a default margin or border for photos; to print borderless photos, you'll have to remove the default margin.
  • 0helpful
    How to print borderless 5 x 7 pictures using an HP psc 1310 series printer I'm using 5.0" x 7.0" hp premium glossy photo paper and a hp psc 1310 series printer and i cannot align the paper properly to...
    Open printers window, right click on the psc printer icon , select printing preferences, click on paper\quality tab, select the paper size as 5x7, check the option as borderless printing and click on apply and then oK...
    Try to print ,,,
    Hp 6500 misaligns printing on labels. can print same labels on other printers.
    I determined that if you set the paper type to
    " Borderless A4" (in printer properties/preferences- just tick the "borderless" box) then all works OK.
    2answers
    HP C4480 Won't Print Borderless
    Most pix you shoot are not exactly 4x6 which will leave white edges top and bottom- Sides Try using the HP software- see if any difference Inkypete
    8helpful
    2answers
    MP600 with Mac OS X - no borderless printing option?
    I had the same question. I found the answer at Canon's site but I can't link directly to the page so here's how I found the solution...
    1. Go to the Canon Support site. 2. In the "Please enter your question field" type: How do I Print edge to edge? 3. Hit the "Search" button. 4. Click the #1 (top) search result "How do I Print edge to edge?" 5. Click the #1 (top) solution: "Use Borderless Printing (Mac OS X) MP600 6. Follow the directions.
    It seems the main thing you need to do is go to the "Page Setup" dialog. Then make sure you've chosen the MP600 in the "Format for:" popup menu. Finally, in the "Paper Size:" popup, select "A4" then "A4 (borderless). It's a hierarchical menu.
    FWIW I still haven't gotten a "perfect" borderless print. Seems you gotta get the paper in there exactly straight...
    Borderless printing kodak 5500, clear coating business cards
    The paper size must be set to borderless in both the application (MS Word) and the printer driver. To set borderless printing in the application, follow the steps below.
    1. Click File , then Page Setup .
    2. In the Page Setup dialog box, click the Paper tab.
    3. Under Paper Size, select the appropriate borderless paper size.
    To select borderless printing in the printer driver, follow the steps below.
    1. In the application, click File , and then click Print .
    2. In the Print dialog box, click Properties , and then click the Paper/Quality tab.
    3. Select the appropriate borderless paper size.
    HINWEIS: Under Paper Type, you cannot choose plain paper and print borderless. Choose photo or brochure paper instead. s.gif
    1helpful
    k24674
    Grand Canyon Tech
    Grand Canyon Tech
