Question about Samsung R610-64G Laptop
Left click button on samsungR519 laptop seems to be 'stuck on' so is clicking on everything you rollover with cursor
Posted by emstep37 on
Frank Zabroski
    Sergeant:
  • 268 Answers
Does this issue persist even after rebooting? Is the same true when using a usb mouse?
Answers to these question will assist in resolving your issue at hand.
Depending on the button type there is usual a mechanism that sometimes fails not allowing the button come back up. This will require a part replacement and work will need to be done by a professional Laptop Tech
My I recommend Live-Tech Laptop Mail In Services
Live-Tech 1-888-361-8511
Thanks Frank.
Posted on May 24, 2010
Cursor and text jumps for dell inspiron 1150
Click the Windows "Start" button or press the "Windows" key. The "Start" menu opens. Type "Cursor blink" in the "Search programs and file" text box. A list opens. Click "Change Cursor Blink Rate." The "Keyboard Properties" window opens. Click the "Speed" tab. A list of options appears. The "Cursor Blink Rate" section shows a "Cursor Blink Rate" slider displaying a range from "None" to "Fast." Click and drag the slider button to the "None" area in the far left portion of the "Cursor Blink Rate" scale. Click "Apply." Click "OK." The cursor stops flickering on the screen.
Feb 04, 2013 | Dell Inspiron Computers & Internet
Logitech m 705 mouse pointer flickering
A list opens.
Click "Apply."
hope this helps
Sep 12, 2012 | Logitech M705 Wireless Marathon Mouse,...
My sreen resolution and font size is large i can't go back to the smallest size i tried going to my desktop properties but it still shows that the fonts and the screen resolution are in their smallest...
Not knowing the make & model of your laptop can only suggest you try to do a system restore. Assuming laptop is running Windows XP, do the following...
1. on the bottom left of the desktop, click on the start button
2. on the start window, hover cursor over All Programs
3. on the All Programs window, hover cursor over Accessories
4. on the Accessories window, hover cursor over System Tools
5. on the System Tools window, click on System Restore
6. on the System Restore window, click radio button to set to Restore my computer to an earlier time
7. then click on the Next button at the bottom of the System Restore window
8. on the Select a Restore Point window, click on a bold date prior to your mistaken uninstall date
9. with the bold date for the Restore Point selected, click on the Next button at the window's bottom
10. on the Confirm Restore Point Selection window, confirm your date by clicking the Next button.
Apr 28, 2011 | Computers & Internet
My cursor moves as i type what can i do
You seem to be brushing against the touch pad while you're typing. You need to adjust the sensitivity of that touch pad:
Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound." You can also left-click the touchpad while the cursor is anywhere on the desktop. From that screen, choose "Mouse Pointers." Select the "Buttons" tab at the top of the dialog box that opens. This shows the type of touchpad device installed on your laptop. Set the touchpad for right or left-handed use from this dialog box. You can adjust the double click speed of your computer as well. When you finish making any changes, click "Apply." Pick the "Device Settings" tab from the dialog box now. You can see the touchpad for your Vista machine highlighted on this screen. Select "Settings." Read the information provided in the next dialog box. It gives you options for tapping your touchpad, using the buttons, scrolling, pointer motion and sensitivity. Make any changes you want from the various topics. When you make a change, click "Apply." Click "OK" when you finish making all your changes. Do some work on your computer for a while. If the touchpad is still too sensitive, return to the "Mouse" menu and continue to adjust the settings until you get them just the way you want them.
Jan 01, 2011 | Computers & Internet
I don't know what the red button does.
The red button in in keyboard is your "trackpoint" mouse cursor, it moves the cursor around the screen
Jan 12, 2010 | IBM ThinkPad T40 2373 Notebook
Acer Aspire Netbook..Can't use keys or right/left click.
go to control panel then mouse properties you will see the buttons the left & right then click the task that you want to do.
Aug 06, 2009 | Acer Aspire One Netbook 8.9" Notebook
Touchpad seems to be sticking
please install ur touchpad driver again
Mar 18, 2009 | IBM ThinkPad T40 2373 Notebook
Left click won't work.
Sounds like the shift or command or control buttons are stuck on your keyboard.
Mar 17, 2009 | Apple MacBook Mac Notebook
Right & left click buttons not working
hmm quite interesting
has your laptop suffered some damage
i recomend you try to disassemble your laptop and check the connector for the touchpad.
dont know how try this site:http://repair4laptop.org/disassembly_acer.html
Nov 30, 2008 | Toshiba Satellite A105 Notebook
Samsung R610-64G Laptop Logo
223 people viewed this question
Top Samsung Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
ThaMp3Doctor
ThaMp3Doctor
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
