Question about Dremel Variable - Speed Multipro Rotary Tool 395
I need part # 2615294309 coupler for a 395 Dremel tool
Posted by phancock001 on
Anonymous
    New Friend:
I had the same problem - couldn't get the part (plastic coupler between the spline drive shafts). I purchased a waterproof **** Splice (GB-AMT-5126 12-10 gauge -- used for electrical wire splicing -- got it at Home Depot). Clipped off about 3/8" on each end with diagonal cutters and attached it to the shafts. The steel ring in the middle of the **** Splice connector provides good structural support to the connection. Works like a charm. Plus with a pack of 4 connectors, I have 3 in reserve.
Posted on Jun 28, 2010
Anonymous
I was looking for the same part and found it on ereplacementparts.com, specifically, the following link for $1.38
http://www.ereplacementparts.com/coupling-p-407237.html?osCsid=sedcbno0cejj50eqkiqes56ep3
In the meantime I had enough of the coupler left that I could just center it and still use it to turn the shafts. I then reinforced it by twisting electrical tape around it so it wouldn't just shatter during use like the rest of it had. It works for now. I wouldn't call it a permanent solution, but it should hold until the new coupler arrives. I think I may just go ahead and reinforce the new coupler with electrical tape when I get it, in order to get longer use out of it before the plastic goes brittle and shatters like the original did. At that price, I will also order extra couplers to keep in reserve.
Hope this helps!
Posted on Aug 13, 2010
3 Related Answers
Anonymous
SOURCE: obtaining a manual
dremel manuals are found here: http://www.dremel.com/en-us/CustomerService/ManualsAndLiterature/Pages/default.aspx
enjoy.
james
Posted on Sep 23, 2008
Anonymous
SOURCE: My Dremel tool motor still works but shaft won't turn?
Here's the email from I got from Dremel (in my case the flex coupling broke):
Inside the tool is a flex coupling and spline driver.
The flex coupling is # 2615294309 and the price is $ 1.25.
This is the hollow plastic sleeve about 1" long with grooves on the
inside, that goes between the motor shaft and the output shaft.
The spline driver is # 2615294308 at $ 1.00.
Spline driver sits on the direct end of the motor shaft. The flex
coupling sits over the spline driver. Spline driver is about 1/4",
hard plastic with grooves on the outside.
Total shipping for orders under $ 5.00 is $ 2.50. Orders over $
5.00 is $ 4.00.
I have provided ordering instructions below.
To order by phone: 1-800-437-3635, Monday-Friday from 7 am to 6 pm
central time. VISA, MasterCard or Discover is accepted.
To order by mail:
Dremel
4915 21st Street
Racine WI 53406
Posted on Apr 17, 2010
Anonymous
  • 3 Answers
SOURCE: dremel moto tool model 395 coupling from motor to
The part that goes between the motor and the chuck is called the CLUTCH UNIT,
REF 2615294309 it is a splined rubberised sleeve, it also fits the 276 and 396.
The price is £3.69 (including vat at17.5%) and can be obtained from Jaymac (Derby) Ltd.
http://www.dremel-direct.com/acatalog/service.html
Posted on Sep 26, 2010
Have Dremel MOD 395 motor runs and speed control works bot shaft won't turn--worth fixing ??? and how
Hi Larry, The tool that you require parts for was discontinued many years ago. Limited parts are available from Dremel. Inside the tool is a flex coupling and spline driver. The flex coupling is # 2615294309 and the price is about $ 1.25. This is the hollow plastic sleeve about 1" long with grooves on the inside, that goes between the motor shaft and the output shaft. The spline driver is # 2615294308 for about $ 1.00. Spline driver sits on the direct end of the motor shaft. The flex coupling sits over the spline driver. Spline driver is about 1/4", hard plastic with grooves on the outside. Total shipping for orders under $ 5.00 is $ 2.50. Orders over $5.00 is $ 4.00. There could be a tax charge depending on which state you live in. Here is how to order: Call Dremel Customer Service at 1-800-437-3635 , Monday-Friday from 7 am to 6 pm central time. VISA, MasterCard or Discover to place a Visa, MasterCard or Discover order. To order by mail: Dremel 4915 21st Street Racine, WI 53406 USA 1-800-437-3635 ext. 3636
Feb 14, 2013 | Dremel Variable - Speed Multipro Rotary...
On the 395 Dremel, where can I buy a coupler?
HOME DEPOT OR ONLINE AT DREMEL.COM
If you need more help post back!
Thumbs and testimonial are welcome!
Jul 08, 2011 | Dremel Variable - Speed Multipro Rotary...
PLASTIC GEAR INSIDE THAT CONNECTS SHAFT TO MOTER SHAFT DISINTEGRATED
I found a coupling part at ereplacementparts.com and the part number is 2615294309, but I would recommend calling Dremel direct at 1-800-437-3635 to ensure this is the right one. They made a change on this coupling. Let me know if you need more assistance.
Apr 17, 2011 | Dremel Variable - Speed Multipro Rotary...
Want to purchase replacement for discontinued Dremel part 2615294309 coupling device, (6 mm inch inside diameter, 10 mm outside diameter, 25 mm long)
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 17, 2011 | Dremel Variable - Speed Multipro Rotary...
Dremel moto tool model 395 coupling from motor to
Jul 19, 2010 | Dremel 395 Variable Speed Multipro Rotary...
5.00 is $ 4.00.
To order by mail:
Dremel
4915 21st Street
Racine WI 53406
Dec 06, 2009 | Dremel Variable - Speed Multipro Rotary...
Nylon Coupler crscks when installing
I'll answer last question first. They might be cracking because they are in a bind and when turned on or inserted on the shaft there is too much pressure. Make sure the shafts are free of any debris from the original coupling, also check the bearings for wear or being so tight that they twist the coupling. Everything should move freely. And second I would recommend calling Dremel direct at 1-800-437-3635 for replacement parts. Hope this helps.
Dave
Dec 26, 2008 | Dremel Variable - Speed Multipro Rotary...
Coupling broke
I have a Dremel 395 Type 3. Motor works fine, shaft doesn't turn. Took it apart to find that the white plastic or nylon flex coupling on the shaft had crumbled and the spline driver, which fits directly over the motor end of the shaft was somewhat worn. I emailed Dremel and got an overnight reply listing the 2 parts I need and the cost: Coupling is $1.00 and the driver is $1.25. Placed order by phone: 1-800-437-3635. I ordered 2 of each in case future replacement is needed. Total bill came to $7.27 including Florida tax and shipping. Can't beat that. They said it would be in the mail by tonight. (Flex coupling number is 2615294309; spline driver is 2615294308.)
Rating Locked! (?) lexrehabtech has rated this solution as Helpful
Oct 26, 2008 | Dremel Variable - Speed Multipro Rotary...
Dremel Variable - Speed Multipro Rotary Tool 395 Logo
2,021 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
Sheldon Dedek
Van Allen
Van Allen
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
