Question about GE Freezer  14.8 Cu. Ft. Manual Defrost Chest Freezer
I defrosted my ge deep freezer now it wont come back on what can cause this?
Posted by rhonnmrslng on
2 Related Answers
Anonymous
SOURCE: deep freezer drain
drain hole block-up. u need to defrost freezer
Posted on Apr 15, 2008
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: my GE deep freezer seems to be getting warmer.
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 12, 2010
Have upright frost free freezer alarm is going off about once or twice a day.Put a thermometer it is around 20 degrees I mute the al;arm and it beeps again and again after several hours. looked to clean...
Hi most deep freezers operate at 0 dergrees. your model may have 2 temp zones. 0 or 20 deg.I'm gessind that your sensor is going off when the defroster is on to melt ice (defrosting). Lower the setting. monitor and repeat as needed. if it continues you may need to replace the unit or ad freon. If the unit is over 13 years ge a new one.
Jul 21, 2011 | Kenmore Freezer 20.3 cu. ft. Frost Free...
How to close the deep freeze
click on it with shift and type your password and restart the computer
Jun 19, 2010 | GE Freezer  14.8 Cu. Ft. Manual...
My GE deep freezer seems to be getting warmer. There only seems to be a freezer sensor panel. Does this mean that the sensor is broken or is there another way to get the freezer back to a deep freeze?
heatman101
Dec 03, 2009 | GE Freezer  14.8 Cu. Ft. Manual...
Self defrosting deep freeze not defrosting
The excess frost in those areas is probably caused by leaky door gasket seals. They should be tight enough to hold a dollar bill securely all the way around. A defrost problem would start on the coils behind the back cover inside the freezer and would also appear on the back wall before it did on the door edges.
Jul 13, 2009 | Amana 19.6 cu. ft. / 555 liter Upright...
My ge side by side fridge freezer coils in back of freezer keep freezin up what could it be i can fix it but havin hard time trubble shootin it?
if your freezing up then your unit is not going through defrost cycle. usually with ge refrigerators its most likely the defrost heater. but check and verify defrost timer and thermostat
Jun 22, 2009 | Freezers
General electric 5.0 chest freezer has water coming all over the floor.
The reason this happens is because the defrost timer is not turning back on when it needs to, causing the freezer to thou out and overfill the drip tray sitting on top of the compressor. A new defrost timer should be available from the local refrigeration wholesalers in your area.
May 11, 2009 | General Electric Chest Freezer FCM5SU
G.E. 20.3 CU FT UPRIGHT FREEZER
Check condenser fan to see if it's working. It's the fan next to compressor
Nov 20, 2017 | GE 20.3 cu. ft. / 575 liter Upright...
Deep freezer drain
Apr 12, 2008 | Freezers
Ice build up in my frost free upright freezer
I looked at the BACK at the bottom underneath of my Sears Kenmore frost free upright freezer and what was causing the ice buildup was very simple. At the factory, the assembler looped the little hose too high and when the water went into the hose it could not get out due to being too high in one spot! An ice dam will form, blocking ALL water coming through
and freezing up any more water coming down giving you a HUGE wad of ice that is scary!!! I just removed the screw holding the loop that holds the hose and put a bit of warm water down the little hole on the INSIDE (Behind the grate) to melt the remaining ice in the tube.You need to take out 4 screws and remove the grate to see this. I could not believe that this was the problem! I haven't had any ice build up since.Now don't tear your freezer apart before you try this trying to fix the compressor, thermostat etc. It may be the only thing wrong with it!
Nov 11, 2006 | Kenmore 16.7 cu. ft. / 473 liter Upright...
GE Freezer  14.8 Cu. Ft. Manual Defrost Chest Freezer Logo
150 people viewed this question
Top GE Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Are you a GE Freezer Expert? Answer questions, earn points and help others
