Canon ZR200 Mini DV Digital Camcorder Logo
Question about Canon ZR200 Mini DV Digital Camcorder
Recording playback has lines through it.
How do I stop the camcorder from recording lines. when I record, the playback has lines in it
Posted by richard_w309 on
hari narayana
    Problem Solver:
  • 10 Answers
Try with head cleaner tape 2 or 3 times mostly it works if not change video head assembly
Posted on May 26, 2010
Anonymous
    New Friend:
What is the video head and how easy is it to change?
Posted on Jul 15, 2010
2 Related Answers
Anonymous
  • 73 Answers
SOURCE: camcorder recording problem
if 600 sgd is labor only - around 400 usd - you might consider cost of trading up to a newer model ( check ebay for second camera , while you wait for . . . warranty repairs ) ;
Posted on Sep 05, 2007
Nasirm12
SOURCE: Camcorder doesn't record I just see a blank screen with multicoloured vertical lines
It is a manufacturing defect in a chip. Canon is replacing it irrespective of warranty. See below URL:
http://www.imaging-resource.com/NEWS/1128632808.html
Posted on Jun 12, 2008
I have a DVD/VCR recording device and I need to hook up my camcorder to record videos to a DVD to submit to an organization for my son to receive a service dog. I can hook up camcorder straight to TV...
To record to the DVD, connect the A/V cables from the JVC GR-D347U to the A/V In on the DVD recorder. Since the DVD already plays to the TV, you just have to keep the TV set to that input. Put a blank DVD in the recorder. Set the DVD recorder to record on from the appropriate Line In (input) with the DVD as the target recording media. To make sure that all of the devices are on and receiving the output from the camera and DVD recorder, start playback on the GR-D347U and check that it displays on the TV. Forward the tape in the camera to the point where you want to record to the DVD. Stop playback. Press REC for the DVD recorder and restart your playback. Press stop for both the DVD recorder and then the camera when the desired video segment has been played back.
See page 21 of the manual for the GR-D347U. Treat the DVD recorder as a VCR for this situation. The manual is available here: https://www.manualslib.com/manual/82266/Jvc-Gr-D347u.html?page=21#manual .
I hope this helps. Please add a comment with the details of the DVD recorder for more information on connecting the unit in this daisy chain.
(Many recorders have at least two composite video Line In inputs. That's why you need select the correct one for recording.)
2answers
Panasonic camcorder playback and recording problem
We need more details on the problem,
Does the camcorder stay on, or it switches off , when the recording stops ?
Play back poor now Camcorder does not record
The head is dirty or bad - insert a brand new blank tape in the camcorder and perform a record through the entire tape without stopping the process until it finishes the record all the way through - this should clean the heads. Playback a pre-recorded tape. If it plays back ok then attempt an actual record. If unsuccessful, then the heads are bad.
I have a blue screen during playback mode on my Sony DCR-HC32. I am not able to see anything I recorded. What should I do?
Follow this procedure to troubleshoot if a blue screen is displayed when attempting to playback video from the camcorder.
  1. Stop the tape.
  2. Ensure the tape has been rewound to the beginning of the video recording.
  3. Play the tape.
  4. If the issue is not resolved, stop the tape and remove it from the camcorder.
  5. Clean the video heads of the camcorder using a dry head cleaning cassette.IMPORTANT: Follow the instructions for use provided with the head cleaning cassette. It may be necessary to use the head cleaning cassette more than once per session.
  6. Reinsert the tape into the camcorder.
  7. Play the tape.
  8. If the issue is not resolved, stop the tape and remove it from the camcorder.
  9. Insert a different tape with video footage into the camcorder.
  10. Ensure the tape has been rewound to the beginning of the video recording.
  11. Play the tape.
Lines across screen on playback.
A Q-tip should never be used to clean a video head.  Unfortunately they can pull the tiny head out of alignment.  I believe this is your problem and the repaid may be more costly than a new purchase.
1helpful
Solid blue lines through Picture on playback mini DV PV-gs19
One possible cause is that normal recording
could not be performed because the heads were
dirty at the time of recording. Clean the heads,
and perform recording and playback again. If
normal playback can be performed, the heads are
clean. Before an important recording, be sure to
conduct a test recording to make sure that normal
recording can be performed.
≥If the heads become dirty soon after cleaning,
the problem may be the tape. If so, try another
cassette.
≥During playback, the picture or sound may be
interrupted momentarily, but this is not a
malfunction of the Camcorder. (One possible
cause is that the playback is interrupted by dirt
or dust that momentarily adheres to the heads.)
Camcorder recording problem
Unable to view or record video
i fear you have a bad CCD. replacement of the same may rectify the problem.
Recording From An External Device
The following Models can be used as a recorder to record from a VCR, TV or another Camcorder. 2004 - SC-D107 2003 - SC-D5000, SC-D27 2002 - SC-D180 Recording In Player Mode 1. Connect the camcorder to the VCR or TV with the AUDIO/VIDEO cable (provided) (to the A/V Outputs on External Device) 2. Set the power switch of the camcorder to PLAYER mode. 3. Turn on the VCR or TV. 4. Insert the blank tape with protection tab closed into the camcorder. If you want to record from a connected VCR, insert a recorded VHS tape into the VCR. 5. Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. 6. Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. "AV IN" and picture appears on the LCD monitor. OUT : Releases the INPUT mode. 7. Press the START/STOP button to set the camcorder to REC PAUSE mode. "PAUSE" appears on the LCD monitor. 8. Select the TV program or playback the VHS tape. 9. Press START/STOP button to start recording. If you want to pause recording for a while, press the START/STOP button again. 10. To stop recording, press the (STOP) button. Notes: * Recording from an analog VCR to the camcorder is only possible when the VCR is playing back at normal speed. * If you want to see the camcorder picture with a TV, set AV IN/OUT in the menu to OUT.
Open Questions:
See all Canon ZR200 Mini DV Digital Camcorder Questions
Top Canon Video Cameras Experts
NOEL
NOEL
Lawrence Oravetz
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
