Question about Gateway FX4710-UB003A Core 2 Quad Q9300 6GB DDR2 640GB NVIDIA GeForce 9800 GT Windows Vista... PC Desktop
Cant turn off tap and click. There is no icon for this in the mouse features area. Also want to disable touch pad scrolling.
Posted by bluzdnce2 on
5 Related Answers
Sauce1234
  • 25 Answers
SOURCE: inoperative touchpad scroll zone
I had the same problem, but I fixed it.
Click start, type "msconfig," go to the "startup" tab, make sure that "synaptics pointing device driver" is checked. After you check the box, restart.
Posted on Dec 23, 2008
Anonymous
  • 10 Answers
SOURCE: how to set up mouse pad so it works with touch
Check in the control panel under mouse. There should be a setting to enable tapping. If there is a touch pad icon on the bottom right of the screen you can also right click on that and select options.
Posted on Dec 31, 2008
Anonymous
  • 11 Answers
SOURCE: scroll bar on the right side of my touch pad scrolls too fast how do i slow it down
It depends, do you know if there is an icon down in the taskbar near the clock that has options for your mouse, if there is then you would double click that and there should be options in there.
Posted on May 26, 2009
Anonymous
SOURCE: Mouse moves on its own
Go to control panel
Go to mouse
Go to pointer options
Uncheck enhance pointer precision
Apply
Posted on Jul 19, 2009
tagh1
SOURCE: Gateway notebook touchpad
Thank you mewms_14904. The problem was the F key. In my case it was F7 that enables and disables the glide pad of my notebook.By pressing fn key and then F7 solved my case.
Posted on Oct 11, 2010
Activate/deactivate touchpad
FN or function key and the icon key that looks like a mouse or touch pad. That combination will activate and also deactivate this mouse or touch pad feature.
Hope this helps ya.
Nerd Tech Junkie - Will
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Dec 04, 2016 | Computers & Internet
I want to turn off the scrolling on my touch pad
1. Locate the Touchpad icon in the area near your clock, in the bottom right corner area of your screen. Known as the System Tray. Thi icon may look like a picture of the touchpad. Some systems may have a different lookint icon. You can place your pointer on each icon and you will get a baloon identifying the icon.
2. Once you find the icon, then Right Click on it and select Pointind Device Properties or the similar option on your system.
3. Click on the Device Settings tab, and then Settings in the box that opens. Known as the Mouse Properties window.
4. Adjust the settings for scrolling, tapping or other features you wish to change by following the directions on your screen. When finished click on OK and it will exit while applying the changes.
Apr 09, 2011 | Computers & Internet
How do I disable touch pad from Dell Latitude E5400
You may disable the touch-pad by following the steps mentioned below:
  1. Click Start and then Control Panel
  2. In Control Panel, click on the Mouse icon. Note: If the Control Panel is in Category View, under View by, click either Large icons or Small icons.
  3. In the Mouse Properties window, click on the Device Settings tab.
  4. In the Device Settings tab, click on the Settings button.
  5. Check or uncheck the checkbox next to Enable Tapping then click OK.
  6. On the Mouse Properties window, click Apply then OK.
Hope this helps..
Feb 20, 2011 | Dell Latitude E5400 Laptop
How do you turn off the touch pad
Some notebook users find the touch pad annoying because at times, while typing fast, their thumbs accidentally brush up against the touchpad. This is frustrating because the mouse cursor jumps to a random location on the screen and can cause undesirable things.
To turn off the touchpad when an external mouse or other pointing device is present, you can goto the Control Panel and double click the Mouse properties icon.
Click the Device Select tab and check "Disable Touch Pad when USB Pointing Device is present." The cursor will no longer move via the touchpad.
Oct 24, 2010 | HP Pavilion dv4000 Notebook
Vertically and horizontally finger scrolling on my vaio laptopnw series is not working any more or maybe i have deactivated it,i had a touch pad icon on my toolbar hiden icons before ,but not anymore.how...
Hi sheki_68,
If you have disabled the Scrolling Feature of the Touchpad, you will need to re-enable for the function to work correctly. You can enable the Touchpad Setting from the Control Panel, Mouse Options.
  1. Click the Start button and then click Control Panel .
  2. In the Control Panel window, click Hardware and Sound .
  3. In the Hardware and Sound window, click Mouse .
  4. In the Mouse Properties window, click the Function tab.
  5. To enable the Scroll function, click to check the box next to Use Scroll Function.
  6. Click the OK button and then close the Hardware and Sound window.
This should re-enable the Scrolling Feature of the Touchpad. If the Function is not available in the Mouse Properties window, you may need to re-install the Touchpad Driver in the Computer to fix it.
Good Luck!
Hope this helps.
Please post back if you require further assistance.
Thanks for using FixYa.
Oct 20, 2010 | Sony VAIO NW270FS Series 155" Notebook PC
How do I disable touch pad when using a mouse? ASUS K50IJ Win7 64 bit
Alternatively, you can permanently disable the touchpad of your laptop by clicking the "Disable Device" in the Touch Pad setting. Advanced users can disable the touchpad from the BIOS setup [press F2 when the computer is booting to enter BIOS settings]
Unfortunately, there are no keyboard shortcuts to enable/disable Touchpad movement or tapping. You can however drag the Mouse icon from the control panel to your Quick launch bar for quick access.
If that sounds too much effort, you may consider adjusting the sensitivity of the touchpad. This can be accessed from the Touch Pad tab of our mouse properties. Choose a low setting.
You can also go to link below to get help.
http://labnol.blogspot.com/2007/05/disable-touch-pad-of-your-laptop-avoid.html
Dec 30, 2009 | ASUS A6U Notebook
Toshiba touchpad scrolling
Go to the Classic view of Control Panel...click on Mouse...click on Device Settings...click on the Settings button..it will bring up a new window about Synaptics....click on Virtual Scrolling. Un-click the horizontal and vertical scrolling button and click Apply down at the bottom and it is disabled. YAY!
Sep 02, 2009 | BenQ Joybook 5100U Notebook
Touch pad
your touch pad might be disabled find the fn key + touchpad icon usually found between F1 to F10 the icon is like a square with pointer above it
Nov 20, 2008 | Computers & Internet
Turn off scroll button
hold down the fn key and press the scroll button.
Oct 11, 2007 | HP Compaq Evo Notebook N115 (470035-737)...
Gateway FX4710-UB003A Core 2 Quad Q9300 6GB DDR2 640GB NVIDIA GeForce 9800 GT Windows Vista... PC Desktop Logo
168 people viewed this question
Top Gateway Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
