It looks like there is no manual. Although it has a German name, it looks like it is made in China and sold by Sonic Electronix and Amazon. Sonic's website says it is down for maintenance, but my guess is they have done a runner!
The manual for the Volfenhag ZX 7190 amplifier will provide the specific instructions for connecting the amp to your system. Here are some general steps for connecting a car amplifier:
Connect the power cable: Run the power cable from the battery to the amp, making sure that it is securely connected.
Ground the amplifier: Connect the ground wire from the amp to a metal surface in the vehicle, such as a bolt on the chassis.
Connect the RCA cables: Run the RCA cables from the head unit or source device to the amp, and connect them to the input jacks on the amp.
Connect the speaker wires: Run the speaker wires from the amp to the speakers, making sure to match the positive and negative connections.
Turn on the amp: Turn on the amp by switching the power switch to the on position.
It's important to make sure that the amplifier is properly connected to avoid damaging the amp or your vehicle's electrical system. Additionally, you should also refer to the manual for your specific Volfenhag ZX 7190 amplifier, as the connection process may vary based on the model and features.
Anythings possible but would not justify the cost of the upgrade. What be cheaper to get a new one with more watts.. No one really upgrades amps as the cost of new ones are so affordable.
its very easy to hook it up. your best bet is to join www.carstereo and ask your question there.but it is easy to set and hook up amp if you really need help email me
Turn your amp over and you'll see 4 holes one in each corner and you should gotten 4 v shapped pieces of metal with 2 holes each and 4 screws.....you normally have to mount them on manually. I hope that helps.
