Garmin Nuvi 660 GPS Receiver Logo
A
Anonymous Posted on May 20, 2010
The touch screen on my Garmin Nuvi 680 no longer works. Any ideas for repair?
SHARCNET-USA
Level 3:
  • Garmin Master 2,130 Answers
  • Posted on May 24, 2010
SHARCNET-USA
Garmin Master
Level 3:
Answers
2130
Questions
Helped
782491
Points
4950
I am looking for a repair manual.. Does anyone have one in digital format?? 2.5 yo Nuvi 680 na touch screen stoped working. matbe a bad connecton.. I cant get it open there are only 2 screws I can see...
If the Touch Screen isnt working, have you tried to recalibrate the screen?
Turn off the Nuvi and then back on.
Slide Power key to the right (lock )
Hold your finger on the screen for about 30 seconds untilthe calibration screen appears.
Follow the on-screen instructions...
Also the 2 screws you took off once you done that you would have to use a plastic pry tool to lift cover up
1helpful
Garmin Nuvi 680 no longer has any audio
Hello :
It's a common software problem with your device . To correct the problem I recommend you to reset it .
Here is how to reset your device :
1:Turn the Nuvi on.
2:Touch the tools icon on the main screen. The tools icon is represented by a wrench surrounded by a blue circle.
3:Touch the "Settings" icon which appears as a wrench.
4:Push the "Restore" button at the bottom of the screen. A confirmation message will appear asking to confirm restoring the Nuvi to factory settings. Push yes to restore the factory settings
Try this for hard reset .
Turn off Garmin device. Press down on bottom right corner of the touchscreen [ Don't let go ] , and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
PLEASE DON'T FORGET TO RATE !
I have a Garmin Nuvi 680 and the touch screen stoped working.
The touchscreen needs to be replaced. Please see this link which explains why this happens:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
4helpful
2answers
Garmin Nuvi 680 Touch Screen "touch" works intermittently
Recalibration has nothing to do with repairing this problem. If the touchscreen is non-responsive, how are you going to recalibrate it when it doesn't recognize the key presses?
The problem is caused by a defective touchscreen. SHARP substitued a different touchscreen into the 6xx series that fails even when the glass isn't damaged. The problem is caused by a defect in the manufacturing process where the touchscreen connections becomes detached from the tail that plugs into the board.
The touchscreen connections between the screen and the tail are made from conductive ink that can fracture, most likely caused when pressing on the screen over time.
These defective screens can be identified by a white tail cap at the end of the tail, whereas the original touchscreens have a maroon tail cap. The original touchscreens will only fail if the glass has been broken.
I only use the original touchscreens for all of my repairs.
- Jim
My 2 year old Garmin Nuvi 680's touch screen no longer responds. I have tried "re-booting" but that doesn't work. Is there anything else I could try?
there's not much you can do if the screen is not responding.
the solution is to replace the touchscreen preferably at a specialized center.
Touch screen not responsive. LCD screen OK.
Try to calibrate the touch screen .
If not send it to a repair centre they will fix the touch screen for you.
Try here www.satnavrepairservice.com
Regards
Garmin Nuvi 650 broken touch screen
Less than one minute on Google: http://www.palmdr.com/cart/garmin-nuvi-650-660-670-680-complete-screen-p-168.html
Jan 02, 2018 • GPS
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
