Question about Broderbund PrintMaster Gold Version 18
Can I add a watermark to a flyer using Printmaster Gold 18?
Anonymous
    New Friend:
I am trying to install a watermark to a document with print master gold 18. I'm having absolutely no success whatsoever. Anyone withany suggestions
Posted on Oct 23, 2010
I lost my product key to printmaster 2011 gold
Contact your sofware provider. Fixya can't provaide passwords, serial or cracks.
Aug 16, 2011 | Broderbund PrintMaster Gold Version 18
Can printmaster gold 18 be run on windows 7
Broderbund PrintMaster Gold Version 18 is not compatible with Win 7.
The Printmaster Platinum 18.1 is compatible.
Dec 19, 2010 | Broderbund PrintMaster Gold Version 18
HOW TO REMOVE PRINTMASTER GOLD WITHOUT THE DISK
You can use Add/Remove on your system or any free uninstallers program eg Revo Uninstaller (free version), CCleaner.
Aug 27, 2010 | Broderbund PrintMaster Gold 16 for PC
How can i get my address book in printmaster 18
what program is using the address book? if it's outlook or outlook express just go up to the titlebar to filesin files there are 2 options import/export click thisjust do as the promt says and make sure you remember where the {NAME].csv file is being written on your drive. after that just copy the file to your thumb-drive and do the same process in reverse, using the import. OR<g> you could always just get frustrated and type it in manually(hope it's not to lengthy a list)
Dec 07, 2009 | Broderbund PrintMaster Gold Version 18
Why don't they make a CreataCard ''Gold'' that works using VISTA?? I missing this great program
Create a Card is a discontinued product.
Encore has new PrintMaster® Gold Version 18 ($19.99) and PrintMaster® Platinum Version 18 ($39.99) programs, both with Vista support :
http://www.encoreusa.com/products.aspx?SearchTerm=create+a+card
Aug 16, 2009 | Computers & Internet
Cant save to pdf in printmaster gold 17
found the fix for printmaster 18 broderbund pdf saving problems...
1-close all open programs and return to desktop.
2-click START and choose CONTROL PANEL
3-click PRINTER
4-right click on BRODERBUND PDF CREATER, then select PROPERTIES (the broderbund PDF creater properties window will open)
5-click the PORTS tab, then select ADD PORT button. (the printer ports window will open)
6-click NEW PORT, then enter PMPDF in the ENTER A PORT NAME window, then click OK
7-click CLOSE at the PRINTER PORTS window. you will now be looking at the broderbund PDF creater properties window
8-a check mark will be located next to the new PMPDF printer port. click APPLY. the broderbund pdf creator will now be located next to the new port. click OK.
9-exit all windows and restart the computer. once the computer restarts, you can save your project as a pdf file.
Jan 28, 2009 | Broderbund PrintMaster Platinum 16
Can't print any projects from Broderbound Printmaster Gold Version 18
Nobody uses that stuff anymore. Get LibreOffice, learn how to use it.
Apr 06, 2017 | Broderbund PrintMaster Gold Version 18
Broderbund PrintMaster Gold Version 18 Logo
603 people viewed this question
Top Broderbund Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
