Using your Internet browser, you can access the Router’s Web-Based Advanced User Interface. In your browser, type “192.168.2.1” (do not type in anything else such as “http://” or “www”). Then press the “Enter” key.
You will get a set up page where you can disable NAT
Follow me on Twitter
SOURCE: set nat to open
These routers have a setting underneath the advanced tab (within advanced setup) called UPNP.....all three of the active tick boxes need a tick in (by default they don't) and this will sort the NAT stuff out.
SOURCE: Change NAT to open
i have the same problem, ive looked at the thread its the same as myne but when i go on the virtual servers it doesnt say discription or imbound port it just says lan port publick port i dont understand :(
Open an Internet Explorer browser page.In the address bar type - 192.168.1.1
Leave username blank & in password use admin in lower case...
Click on "Applications and Gaming" tab and then click on "Port Range Forwarding" subtab...
1) On the first line in Application box type in ABC, in the start box type in 88 and End box type in 88, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box...
2) On the second line in Application box type in PQR, in the start box type in 3074 and End box type in 3074, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box...
3) On the third line in Application box type in XYZ, in the start box type in 53 and End box type in 53, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box and click on Save Settings...
3) Once you return to the set up page click on the Security tab and uncheck Block Anonymous Internet Requests and click on Save Settings...
4) Click on set-up and change the MTU Size to 1452 and click Save Settings...
5) Goto the XBox Network Settings and IP Address Settings and select manual IP Settings and assign the following on your Xbox
IP Address :- 192.168.1.20, Subnet Mask :- 255.255.255.0, Default Gateway :- 192.168.1.1...
6) Also assign the DNS Addresses on the Xbox
Primary dns :- 4.2.2.2...Secondary dns :- 192.168.1.1
7) Turn off your modem, router, and Xbox...Wait for a minute...
8) Plug the modem power first, wait for another minute and plug the router power cable, wait another minute and turn on the Xbox and test it...it will connect...
Kudos! Thanks!
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: HOW DO I CHANGE MY NAT TO OPEN FROM STRICT?
redu8ce the MTU settings on the router to 1365.
you will also need to open some ports for PS3 on the router.
For this you will need to access the router set up page.
connect a computer to the router. check the IP address on the computer.
according to the default gateway open the router set up page.
Click Here for more information about the routers and network
SOURCE: dlink dir-615 change nat from strict to open
you will need to change some settings on the router.
reduce the MTU. if the MTU settings on the router is 1500 then change 1365 also you will need to open the some ports on the router.
