SOURCE: My name is Andy Smith i am Electrical Engineer on
You need a Tylo cc50 controller and the R30 relay box then you can run it as long as the current capacity of your cable
regards
Andrew UK Saunas Ltd
SOURCE: My tylo supersport 8 sauna
Remove the unit bottom panel (2 small screws) and look at the quick disconnect terminals on the heater rods ( 6 heating rods - 3 on each side of the unit). If you have any corrosion on these terminals, the wires will overheat and fail, preventing the heating rods from working. If the wires did overheat, you should see melted wire insulation. Replace bad wire and quick disconnect terminals with new. Should cost less than $20.
