Question about Dell XPS M1330 Notebook
Hi.I have a dell xps m1330. after use for an hour,...
Hi.i have a dell xps m1330. After use for an hour it will be very hot! can you help me?
Anonymous
    Problem Solver:
  • 15 Answers
Put a cooling pad under the laptop, make sure there is plenty of air movemend by the fans, example. dont sit the laptop on your bed or a pillow or anything that blocks air movement. also, they will tend to get hot if you put a lot of high usage on them as in gaming and such. if you have tried all these and it gets so hot that it locks up or is burning, you, then call Dell it could be an internal issue.
Posted on May 24, 2010
1helpful
I cant get my disk out of my xps m1330 laptop what do I do?
Have you tried using the Eject button on the controls above the Function keys on your Dell XPS M1330 laptop to eject the disk from the optical drive?
If the above does not solve the problem then you may need to refer to the Service Manual for your XPS M1330 which has information on how to remove and replace the Optical drive if this has failed.
How to replace DVD for laptop dell m1330?
Hi cacoffeelove,
You can get the service manual for Dell M1330 from the dell website to help you remove and replace your DVD drive.
Click Here to go to the page that has the service manual. You cannot jump directly to the Optical Drive Section in the manual. You have to go step by step.
If this information was helpful, please rate it.
Thank you for using fixya,
Arun Zac
2answers
The sreen of my DELL XPS M1330 suddenly does not lght up!
It can be either the display is dead or it is a loose connection. If you are still covered by warranty then I would suggest you to contact the dell technical support. They will replace the part for you.
However if you don't have a warranty then you can buy this part from dell online store (the display) and you can fix it on your own - http://ahwee.com/how-to-disassemble-laptop-dell-xps-m1330 follow the instructions here to dismantle your laptop and refix it with the new parts. If you find any troubles doing so; please let me know; I will help you further.
Best Regards NextDoorNerd
How do i replace the back light from my xps m1330 dell
Well first I recommend if you do not already know how to do this, please do not. Second the cathode lights are normally 2 cathode lights, usually 1 on the top and 1 on the side, these are inside the outside plastics and set right up next to the screen, you will have to completely take apart the screen, will take an hour or so.
2answers
Dell XPS M1330 Laptop can't boot to windows, when running express test, got error code 0F00:137B when re-install the vista, it stop at "Expanding files (0%)" long time ...
if you bought this from dell, use the restore disks that came with it starting with disk one. you wont be able to save your files bt at least you will have a usable computer. i have an XPS studio 16 and had to do the same thing.
Dell XPS M1330 PC Notebook can't connect to the external monitor
No. You just basically need a VGA cable. Check your video settings.
Dell xps m1330
The M1330 is not in stock anymore at Best Buy, here is a choice of Dell laptop different models that can be purchased online.
Dell XPS M1330 Notebook Logo
Ekse
Mandeep  Singh
Mandeep Singh
Michael Thomas
Michael Thomas
