TRANSFERRING PHOTOS TO COMPUTER If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
for this ,use a MEMORY CARD READER .
Insert the memory stick into the Memory Card Reader and connect the reader via the USB jack/port to the computer.Go to "my computer",select the M CARD READER which may be indicated as "Removable disk "F".
Meanwhile select the pictures to b uploaded and right click the mouse to select ,"Move to"--removable disk "F"
when all pictures are uploaded ,remove memory stick and insert in camera to see the pics .
If you normally upload your pictures by connecting via the USB port, remove the memory stick before connecting the camera to the computer. If you normally upload your pictures by putting the memory stick into a card reader, use the camera's memory stick tool to copy the pictures from internal memory to memory stick.
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
When the camera writes the image files to the memory card, it also creates index/information files. Without those files the camera will not display the images.
Check the software you used to upload the images with. There's probably a checkbox or option that tells it to delete the images from the card after uploading them.
This one is easy. Buy a memory card reader and do not use the camera usb cord. A card reader will always be the easiest way to transfer photos from memory stick to PC.
Format your camera's internal memory and also format any memory cards you insert.
Use a program called Recover4All to see exactly what is in your camera's internal memory.
Then insert a memory formatted memory card and take some pictures. see if they will upload.
use a sd memory card reader-no software-plug and play-make sure you don't have 2 folders in camera storing pics in different places-check in menus for folder numbers
I have a Cobra camera (I believe it is an 8500) and when I use it without the memory card, it will take pictures. As soon as I put the memory card in, I can't use it. It says I need to digitalize my camera. I put in the date, time, year. Can't take pictures...
This model doesn't allow you to upload photos from a PC to your memory card whilst the camera is connected to the PC. You will need a memory card reader.
