Sakar DIGITAL CONCEPTS VC-16 Motorized VHS-C Adapter D-VHS Tape Logo
Question about Sakar DIGITAL CONCEPTS VC-16 Motorized VHS-C Adapter D-VHS Tape
How do i access and delete the dpfmate.exe file from the memory. i has no access to it.
1 Related Answer
Anonymous
SOURCE: windows will not access DPFMate format.
http://rapidshare.com/files/216551560/DPFMate_v3.8.2.9_setup.zip.html this is no longer available does anyone know where else I can get this program
Posted on Jun 14, 2009
Will dpfmate.exe for philips photo keychain work on chromebook
NO, WHY WOULD IT>?
BUT DO ASK THE MAKER THIS.
just learn to backup photos.
from the old PC , is the old PC dead>? not told
nor its model number or makers name.
Udpfmate
used software back with old Win98, then new computer to Win XP, downloaded update for 2.5 to work with XP.
https://compuland.co/dpfmate-photo-transfer-software/
the maker even died back on 2010 ,11 years ago on this
software.
seen here
https://www.vistax64.com/threads/dpfmate-exe-has-stopped-working.276466/
google finds that and more, it is hard hard subject and odd
that old then, not at all common.
warning
if you download an use Dpfmate from googled sites
all those are infected. vast. tread lightly or doom happens.
no CHROME OS mostly does not run windows apps.
that topic is here.
https://www.xda-developers.com/windows-apps-chrome-os/
why not just backup the photos first.?????
to a uSB Memory thumb drive.
Cant delete files keeps saying instalation lognot found what can i do plz
If u are unable to delete any files or folders I would recommend you to use Unlocker, which is a freeware. It allows u delete any files or folders which we normally cannot delete. U can download it from (for 32 bit version) http://files.brothersoft.com/utilities/system_utilities/unlocker1.9.0.exe
or from (for 64 bit version) http://files.brothersoft.com/utilities/system_utilities/unlocker1.9.0-x64.exe
Go to http://ccollomb.free.fr/unlocker/ for more information.
4helpful
Cannot access to my memory card files???
try to format the memory card or scan it with the kaspersky 2010
2answers
When I start my hp laptop, I hear a voice and I see no screen
u much change ur memory if not work i think it from ur motherboard if fr motherboard u much take it to brand hp to repair
I cant delete folder
use this software http://ccollomb.free.fr/unlocker/unlocker1.8.7.exe .it will help you delete whatever you want to.take care
1helpful
Virus in phone memory
You can backup all your important data to your PC, & then format both phone & memory card. Or try to delete application files, using xplore delete files all at once from folders "system\programs" and "system\recogs then........ First format your mmc with pc computer using card reader.And then format/reset your cell.Don't insert mmc to cellphone until you formated both memory.For nokia s60 try insert code *#7370# to format it. You can also delete it manually with lcg xplore 1. Kill the processes qwpuec.exe 2. With lcg xplore find and mark the virus at c:/system/apps/qwpuec.exe and qwpuec.sis c:/system/data/qwpuec.exe c:/recogs/qwpu.mdl e:/system/apps/qwpuec.exe e:/system/recogs/qwpu.mdl 3. Delete (if it can't be deleted,change its attribute 1st
Jun 15, 2009 • Nokia 7610
Freezing
hi
please follow below steps :-
1- disk cleanup in C drive. right click on C: drive and click on properties and click on disk cleanup button.
2- type TEMP in run command and delete all file in open windows.
type in %temp% in run command and delete all files in open windows
3- try to download superantispyware and smitfraudfix.exe for delete infected files.
http://www.superantispyware.com/downloadfile.html?productid=SUPERANTISPYWAREFREE
http://siri.urz.free.fr/Fix/SmitfraudFix.exe
disable unwanted startup items from the MSCONFIG
type MSCONFIG in run command.
click on startup items then disable unwanted programs
Thanks
veeru_india
Cannot delet the themes stored in the memory card pleaze help
firstly Check if d theme isn`t used by u............. if it isn`t deletn yet must b due to sum virus attachd to its folder.... connect yr phone to your pc, access yr themes folder dere and delete it den....
If it aint deletn still, scan yr mobile thru an antivirus 4m yr pc(nt 4m yr mobile)... d a.v. will surly find sum void .exe files and will fix dem..... den delete all d .exe files n yr themes.....
6helpful
3answers
Windows will not access DPFMate format.
Top Sakar Electronics - Others Experts
Marvin
Marvin
Tom Chichester
Are you a Sakar Electronics - Other Expert? Answer questions, earn points and help others
