Question about Rio Carbon MP3 Player
When I transfer music from Rio Music manager to my Rio Carbon the music manager indicates transfer successful but the MP3 player states no tracks present?
  • Anonymous May 25, 2010
    Have a Rio Carbon that was stuck in record. I found solution on line (to reset it) and did this, have also upgraded with most recent firmware. It is no longer stuck in record, however when I transfer music from Rio Music Manager to the device, the player shows "no tracks" even though I can click on the Carbon in RMM and it shows the tracks as present.
CIROC TECH SUPPORT
    President:
  • 524 Answers
Try to transfer the tracks from the explorer.
1 Connect the Rio Carbon to a computer using the supplied USB cable.
2 Double-click My Computer on the Windows Desktop or in the Start Menu.
3 Locate MP3 or WMA audio files on the computer.
4 Highlight files and/or folders to transfer to the Rio Carbon.
5 Click Edit.
6 Click Copy.
7 Double-click My Computer on the Windows Desktop or in the Start Menu to open another window.
8 In the new window, locate the Rio Carbon (X:) icon that is associated with the Rio Carbon. (X equals the drive
letter assigned to the Rio Carbon.)
9 Double-click Rio Carbon (X:).
10Click Edit.
11Click Paste.
Posted on May 25, 2010
    Either this didn't work or I don't know how to do it. I found the files with the music (don't know how to tell if they are MP3 or WMA files). Highlighted, copied and pasted to carbon as directed. Still do not show up on device. I can however go to my computer, click on the carbon and open it up and play the music on my computer.
Muzahura Frank
  • 2,069 Answers
Copy Music to your Rio Player:
Rio Music Manager will automatically detect when your Rio Player is attached to your computer with the supplied USB cable, and place an icon for the player in the RMM interface. To copy music to the player, simply drag music files from your Windows Explorer window or from RMM right on to the icon. RMM will begin copying the files to your player.
Click on the Rio Player's icon in RMM to see all the files currently on the player, as well as how much space remains. You can also select files in this few and choose delete to remove files from the player.
Posted on May 24, 2010
  • 4 more comments
  • Anonymous May 24, 2010
    I have done that (tried it multiple times)m RMM says transferring music, then player says no tracks. I can click on the Carbon icon in RMM and it shows the tracks present.
    The player had been stuck in record so I needed to reset it, deleting all tracks previously present. Have had this problem only since then.
  • Muzahura Frank May 24, 2010
    ok, now I recommend you upgrade to the latest firmware available. because, if it is corrupted any number of errors can
    occur. After an update, it will be restored and you can resume music uploading. please check here for firmware and upgrade guide.
    regards
  • Muzahura Frank May 25, 2010
    ok then since you say you already upgraded to the latest firmware, just delete them from Windows Explorer and re-transfer them,
    it should work fine.
    Always Use FIXYA!
    Regards
    If I go into RMM and click on Carbon (when it is connected via USB) it shows the tracks as present but when I go to the device to play them it says no tracks. I have used RMM to delete the tracks showing as present and attempted to re-transfer and they are still not on the device.
    Your Rio Carbon can play MP3, WMA, and Audible #2 and #3 format files. try to upload a different file format and see if they will be recognised.
    I hadn't noted that you already rated my attempt to help you poorly..............?
Rio carbon wont load any music?
try reformatting it then putting music back on it see how that helps
Apr 27, 2012 | Rio Carbon MP3 Player
Grace Note not working in Windows Media or Rio Music Manager
you are suffering from the Digital licensing information encryption from the majors, which ITunes will NOT agree to. That's how the music industry is making it's muscle show, with this sort of tawdry nonsense. I don't believe there's a s/w upgrade on this, unfortunately. There is a slight possibility that your software might have an interpreter, yet your Rio being that old, not for certain.
got backup?
Feb 12, 2008 | Rio Carbon MP3 Player
Filels won't delete
Try re-formatting your Rio
On windows just right click on it and click format.
This will remove any tricky tracks that just don't want to go away...
Mowcius
May 26, 2009 | Rio Carbon MP3 Player
How do i download/transfer my rio carbo mp3 music database to my ipod itunes music manager??
The Rio Carbon is completely incompatible with iTunes (which uses AAC format). It only accepts mp3, wma, and some WAV's. The Rio Carbon is still the best mp3 player I ever owned, but since Rio doesn't make them anymore, it will never be compatible with iTunes. You can use it with Rhapsody's Mp3 Only service, or any music service that gives you the files in mp3 format - but you can't sync the songs through the music service's "synchronize function" - you have to download the files to a location on your computer, and then use the Rio music Manager to transfer the songs to your device.
-Tha Mp3 Doctor
Mar 04, 2009 | Rio Carbon MP3 Player
Carbon Pearl: Invalid Argument
Try accessing the rio's hard drive through my computer to see if it can find the songs: they will be in a folder aptly called music within your rio carbon.
If this doesn't help then if it is picked up via my computer you could try wiping and rebooting your rio, read:
http://www.fixya.com/support/r601327-wipe_reboot_rio_carbon
You may have to change the firmware for the rio carbon pearl but this is easy to find on their website.
Hope this helps,
Mowcius
May 22, 2008 | Rio Carbon MP3 Player
How to take music off Rio Carbon
I have bad news - I was completely unsuccessful in dragging tracks from the rio to my computer. You can load songs, but you can't "unload" them with the Rio Carbon.
Just in case your computer has capabilities that mine does not, try this:
Double-click "My Computer" on your PC desktop
Double click the Rio Carbon icon
Double click the "Music" folder
Try dragging a single music file from the "Music" folder window to your PC desktop - it will either work, or it will say that it cannot copy the file to the specified location.
Apr 13, 2008 | Rio Carbon MP3 Player
Tranfer from player to computer?
Go to Main Menu -> Settings -> Advanced -> Transfer Mode and select MSC. Worked for me.
Nov 18, 2007 | Rio CE2100 MP3 Player
Transferring music to new pc
You must use the music transfer software that came with the CD (also avail on Rio website) - which will not load on newer, Vista running computers.
May 03, 2007 | Rio Carbon MP3 Player
Rio Carbon 5gb pearl transfer problem
hi first of all update uour firmware: http://www.replaytv.com/support/rio/product.asp?model=267&SKU=90260554 also go to Software tab and update your Music Manager i belive this will solve all your problems good luck
May 01, 2006 | Rio Carbon MP3 Player
Rio pearl directory corrupted
first, and this is always good: If available, firmware for the Rio Carbon can be downloaded online. Second, this might be the problem: The Rio Carbon communicates with your computer differently in MTP mode than it does in MSC mode. When in MTP mode, the Rio Carbon cannot display hidden files in folders, cannot allow transfers to the root Rio Carbon directory, and cannot allow the creation of new folders. (Folders can be transferred to the Rio Carbon using drag-and-drop and copy-and-paste methods.) To use traditional folder options, change the Transfer Mode settings to put the Rio Carbon in MSC mode. Last, "..Removing the Rio Carbon from a USB connection before Idle is displayed on the screen may result in a corrupting the player's file system. If for any reason you suspect that your Rio player's file system has been corrupted, reformatting the player will restore the file system to its original state..."
Nov 27, 2005 | Rio Carbon MP3 Player
Rio Carbon MP3 Player Logo
Top Rio Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Artur Heise
Jean Sintulaire
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
