Posted on May 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have use the HP Deskjet D1360 series printer paper jam
I have use the HP Deskjet D1360 series printer then to occure the problem of the print paper is jam then to ask it what i do sir plz.......... plz told the correct solution sir..........
Frank Zabroski
Level 2:
Sergeant:
  • Expert 268 Answers
  • Posted on May 24, 2010
Frank Zabroski
Expert
Level 2:
Sergeant:
Answers
268
Questions
Helped
70471
Points
685
Simple and slowly remove the jamm'ed paper. Please be sure to inspect the system in detail (you may need tweezers) for any small pieces of random paper laying around.
After this you should be set please let us know if this issue persists as this would be a sign of other issues.
Thanks
Frank
Live-Tech
1-888-361-8511
A sheet of paper had remain in the cylinder
  1. Remove the rear cleanout from the printer.
  2. Gently remove any jammed paper or bits of paper.
  3. Close the HP Paper Feed Cleaning Kit software on the computer.
  4. Load plain paper in the printer paper tray.
  5. Press the Power button to turn the printer off.
  6. Press the Power button to turn the printer on.
  7. Try printing again. If the printer still does not pick up paper or if a paper jam occurs again, service the printer.
Other solutions customers found helpful » HP Paper Feed Cleaning Kit -- Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000 » HP Deskjet, Photosmart, and PSC All-in-Ones -- 'Out of Paper' Error Message and the Printer Does Not Pick Up or Feed Paper » HP PSC 1600 and 2350 All-in-One Series Printers -- 'Paper jam: Press OK to continue' Message Displays on the All-in-One
4helpful
3answers
Hp deskjet d1360 un able to print,soft ware not exist want to down load
You can download the driver for your HP Deskjet D1360 here:
http://drivers.softpedia.com/get/PRINTER/HP/HP-Deskjet-D1360-Printer-Driver-7-0-2.shtml
Paper jam occurred so i fixed the printer and says ready to print but when i try to print page again paper jam occured
unplug the printer,then manually remove all part of paper, then with a clean spong clean the gear feeding area. wait for 15 minutes plug back.
1helpful
My HP Deskjet D1360 printer green light keep blinking.can't take printout.The machine does't get the paper inside. so send the solution
you have a paper jam
pull out the paper tray, check for the jam if all is well, open the printer, check under the printer cartridge, then the back
a little piece of paper will cause the jam
it is a good idea to use canned air to clean your printer, under the cartridge and the rollers on a regular basis (once a month)
2answers
Paper jam in hp deskjet 5900 series. how do i correct?
 Follow these steps to remove a paper jam:
1. Press the Resume button.
  If the paper jam does not clear, then go to the next step.
2. Turn off the printer.
3. Remove the rear access door. Press the handle to the right, and then pull out the door.
4. Remove any paper that is inside the printer by pulling it out from the back of the printer.
  If you are printing labels, verify that a label did not become detached from the label sheet while passing through the printer.
5. Replace the rear access door securely.
6. If the paper jam cannot be removed from the back of the printer, raise the printer cover, remove the paper jam from the front of the printer, and then lower the cover. Caution Remove the paper jam carefully as it is possible to damage the
  printer when removing paper from the front.
7. Turn on the printer, and then press the Resume button.
8. Reprint the document. Note If paper jams occur frequently, try using a heavier paper. See the reference guide for paper weight specifications.
HP 2360 Paper Jam
pls look the swich for paper inside, maybe the switch did not tuns back to his position
1helpful
3answers
D1360 black ink didn't print and green light keep flashing
just unplug the power cable and usb cable from the back side of the printer and let it be for an hour it will help
6helpful
13answers
Making a CD from internet for printer (Hp Deskjet D 1360
Dear sir, we misplaced the CD of printer model No. Hp Deskjet D1360 . so please help us to make a CD. thank you.
k24674
ADMIN Andrew
ADMIN Andrew
