Question about Fuji FinePix F470 Digital Camera
I'm trying to upload pics but it's not working. what to do?? I plugged it into the computer like always and the battery is fully charged, I connect it and nothing happens.
Posted by csybowes on
Prakash R
    President:
  • 1,382 Answers
I highly recommend that you instead consider using a card reader to move the photos or videos to your computer. Card reader's do not require software (although Windows 98 and earlier may require drivers), are very inexpensive, are much faster downloading files from the camera, do not use the camera's batteries during the download, and are much less prone to file corruption of the photos during the download.
Really, it would be better for the camera user if one of these was included with the camera instead of the cable and bundled software.
You place the camera's card in the reader, plug the reader into the USB port, and your computer sees it as a hard drive. You simply copy/paste or drag/drop your photos onto your hard drive. For this simplicity, most professional photographers utilize card readers exclusively. You'll save yourself a lot of heartache if you convert to using one of these. Also make sure that you get a reader that is clearly stated capable of reading your card, particularly if you use SDHC, XD, CF, or MS cards.
Thank you!
Posted on May 24, 2010
My panasonic Hc-v100 camcorder is not charging when plugged in to USB cable - cursor light is not flashing and battery is running down
you DON'T charge the camcorder with the usb cord,you only move files between cam and computer,you need a power cord that plugs into the wall,see pic, LETO 2A AC Power Charger Adapter USB Cord For Panasonic HC V100 HC V500 HC...
ihave the same camcorder,
Mar 24, 2015 | Video Cameras
My camera will not upload pics, it says that there is no pics/videos to upload at this time! Even though I have 84 pics there!
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Mar 24, 2012 | Kodak EasyShare C143 Digital Camera
I am unable to upload pics from digital camera to laptop
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Nov 12, 2011 | Fuji FinePix J10 Digital Camera
Uploading pictures
Cameras can't upload if low on power. Charge batteries or plug in the ac adaptor to an outlet and try again.
Sep 12, 2009 | Panasonic SDR-H40 HDD Camcorder
My 24280 dig. Wont charge
the pc function means that it is connected to your computer this is good because now you should be able to upload pics and ect...the red light is simply to show its charge level and is always on when plugged in to computer also there should be a switch on the side to change from camera to charge if its on charge and the light is red then its carging and it will turn green when its done.
Jun 16, 2009 | Sakar 24280/24282 Digital Camera
Battery fully charged
thier is a pic of a batterty in the bottom right corner, it will be fully green when charged. otherwise it will be flashing.
Jun 11, 2009 | SanDisk Sansa Clip MP3 Player
BATTERY dead. how to charge?
The battery is removable and the camera came with a charger that you connect the battery to and plug into a household socket.
Mar 16, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon EOS-300D not seen by computer/not turning on
Heat and batteries - maybe Try another battery Remove camera software from computer and put the disk in the box. Plug camera in switch it on and set it to upload mode Windows should find it as a new drive or[XP/2000/ME] will put up camera/scanner wizard.
Aug 06, 2007 | Canon Digital Rebel / EOS-300D Digital...
Fully charged Lithium batteries dies out too quick and the USB cable does not work? Please help. thank you.
If the lithium batteries are of the AA shape then put them in a small torch and leave the torch on to fully run them down. If they are of an odd shape endeavor to do this with bulb wire and tape. Then try recharging them. If this fails- simply get a new set of batteries at first. Then come back
Jun 01, 2007 | Konica Minolta DiMAGE X Digital Camera
Fuji FinePix F470 Digital Camera Logo
54 people viewed this question
Top Fuji Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
