Frigidaire FGF316 Gas Kitchen Range Logo
Posted on May 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The burners are not lighting automatically also they do not click anymore
Anonymous
Level 3:
  • Frigidaire Master 43,501 Answers
  • Posted on Sep 30, 2010
Anonymous
Frigidaire Master
Level 3:
Answers
43501
Questions
0
Helped
10835250
Points
101584
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Burners won't light automatically. Will light with a match. Flint doesn't spark anymore. Can flints be replaced and by whom?
If none of the igniters are working then it is probably the igniter module which is relatively easy to replace on most makes and models.
2helpful
heatman101
hgghs
1helpful
No Clicking Sound
Sounds like the ignitor control module is bad, if none of the ignitors are working. If it is only one burner with a problem, it is likely an ignitor.
My laptop cd burner isn't burning music I downloaded anymore. Everytime I insert disc, made for music, it makes a weird noise says that a disc needs to be inserted (one is already in there) and the tray...
Go to "computer" and right click the drive,Then "properties"then "Hardware"then pick your drive,Then "properties"again,Then click"drivers"then "uninstall" and "OK".After uninstalling the drivers for that drive you need to Reboot,Windows will automatically reinstall and repair the drivers.If after all this work it still refuses to work it maybe a hardware issue,the drive could be bad.Sorry,.............
Gas burners won't light
Make sure the little tiny flash holes are open. They allow a little bit of gas to seep out so the igniter can light the burner. If you can light the burners with a match, check those holes.
If yours are the "sealed" type burners, make sure they are not a half a turn out (180° around)
Jan 10, 2010 • GE Cooktops
Ignighter is not working on any burners
if if does not light anymore you have a ignition sequence fault could be a faulty switch foe the ignition pcb ht lead or electrodes
Ignitor sometimes clicks, sometime not
You will need the ignition bird located il under the cooktop
Gas burner not lighting
make sure the burner ports are not clogged. and the caps are properly positioned. clean ports with a wire or a straightened paper clip if clogged.
make sure the igniters are clean and dry
7helpful
Stove burner igniter does not work.
Your problem is not the igniter itself, but the burner switch that controls the igniter. All the igniters get their power from one spark module that is mounted somewhere in back of the oven. That's why you are able to get all the igniters to spark with only one burner control turned on. This is normal. That is also why you are able to light the burner in question buy turning on another burner. The spark is being provided by a switch that is working. To answer your question: the igniter is removable, but I don't think it's necessary. Cleaning them generally doesn't make them work better. I would check the wiring from the spark module to the burner switch and/or replace the switch. I hope this helps.
Top Frigidaire Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
