Televison & Video Logo
Posted on May 23, 2010
Magnavox tv/dvd/vcr combo model mwc24t5b i put a tape in the vcr hit play and the tv shuts off. everything else work fine on the tv.
enganyada
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 17, 2010
enganyada
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
358
Points
Usually when that happened for me, it meant that one of my small children had also put a foreign object in the slot where the VHS tape goes. Any type of obstruction will cause the VCR to jam and force the television to shut off.
I record a DVD from VCR tape and try to play on another device
In my research, I learned about finalizing the DVD, which was a new concept to me. I looked that process up in the manual and it did the trick.
May Magnavox MWC24T5B tv/vcr/dvd combo will not stay on.
I've found the center LED in the VHS player faulty with those symptoms. Change it you'll be fine. Larry
2helpful
T.V. shuts off when I try to play a DVD in the built-in player
Try putting in a VCR tape let it load and hit stop. If the set stays on it's the VCR deck causing the problem. It will be either be bad sensors or LED or possibly the mode switch. Let me know if this helps.
Magnavox MWD 2206A vcr/dvd combo
you probable have a dirty video head...you can try a tape head cleaner tape/// they sometimes work.... if not you need to get to the video head and clean it with a liquid cleaning solution---
one of your tapes may have a bad spot on it causing the problem...if you clean it and use the same bad tape again you can cause the same problem again
2answers
VCR tape playback not good
Check your "tracking" If the tape played fine in the old machine, then tracking is the answer, provided that the new machine records good.
1helpful
2answers
4helpful
2answers
Magnavox mwd 2206 dvd vcr player....shuts off with eject word across screen.
On a unit I checked with this same symptom, removing the top cover allows the unit to stay on and operate normally. There is some sort of sensor at the left middle of the chassis, which, when unblocked by any opaque object, allows the unit to remain on. A temporary fix (not advisable) would be to replace the top cover with a piece of clear plastic or taut saran wrap (no vent holes needed). It's unclear exactly where/what that sensor is from a cursory test. This is a work in progress on someone else's machine that I lack full access to.
2answers
Magnavox combo vcr dvd
What you're describing is common when the center LED has failed / gone out. If you're really good at taking a unit like this apart and putting it back together - and not too bad with a solder stick you could attempt this one yourself... It is a pretty intensive repair but not difficult for a good shop just time consuming. The part isn't too expensive either, just an infared LED... In fact, we've run a bit short on stock once in awhile and bought one of the off the shelf versions from Radio Shack which worked just fine. Good Luck Bill
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
