Clean or replace IAC valve (idle air control valve).
Try cleaning the idle air controller, its the small guy under the throttle body held by three bolts, if not change and also clean the intake port on the throttle body, that should help
If it is gdi engine it could be the ecu 2 ways to check see if a code reader will work it will not if ecu faulty also try an emission check will read high lamdba low co2 if so you will need to get ecu repaired plenty on line price from about £130
