Question about Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D
I have a 8hp briggs and stratton motor on my ride on mower which is not an electric start can i install and electric starter kit on it
rlev_7
    New Friend:
  • 47 Answers
Yes u need a starter and battery
Posted on Sep 09, 2010
How to wire up my 13.5hp coil & charging system
Only need a simple double pole, single throw toggle switch. One side to power (battery) other to solid ground, to run power to starter motor Starter motor may have a ground on it also. See u-tube video, starting a riding mower.
Feb 12, 2017 | Briggs & Stratton Garden
Valve clearance on 8hp flathead
.014 inlet 016 exhaust. check the settings by going on line for b&s motors and give it a bit extra as they suffer from stretching valve stems
Jun 05, 2013 | Briggs & Stratton Garden
Why is my 8hp briggs and stratton engine keeps bogging down?
it sounds as though the spring on the butterfly on the carb is dirty
Sep 23, 2012 | Garden
Need to know the weight of the motor oil
sae 30 in winter sae 40 in summer i preffer rotela
Aug 20, 2012 | Briggs & Stratton Briggs Stratton Intek V...
How do I drain the oil on a Briggs and Stratton 8hp 191702 ride on mower ? I can't seem to locate the oil drain plug.
if you follow the dip stick tube down to the base of the engine there is a square head bolt that is the drain plug
Jun 27, 2012 | Garden
Have a Yard Machine riding mower with 21hp Briggs Stratton engine OHV/IC V-Twin. when I turn on key nothing happens. How many switches control the start motor from the ignition and where are they located....
It depends on the model but most riders have the following;
1. Seat switch
2. Brake pedal switch
3. PTO switch
4. Neutral switch (if its a shift model)
All need to be closed in order to start engine.
Jun 03, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have crafsman 48" riding mower with a 24 hp intek motor
Bent push rods are a function of the valve guide coming loose in the head. The valve binds and you end up with a bent pushrod. Fix: Replace head. $94.00
Jul 13, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D Logo
584 people viewed this question
Top Briggs & Stratton Hammering Experts
rlev_7
Level 1 Expert
JOHN LAPIER
John Trevino
Are you a Briggs & Stratton Hammering Expert? Answer questions, earn points and help others
