Question about Pioneer DV-350 DVD Player
Hello, I'm trying to display Arabic srt subtitles ...
Hello I'm trying to display Arabic srt subtitles using divx movies. I put an srt file with the same name as the divx movie file but the subs were displayed in an unreadable font. Any suggestions pls?
Anonymous
    New Friend:
If you have Arabic lang. in your windows, and you have the movie (.avi) and the subtitle (.srt) in the same folder with exactly the same name for both 2 files, and you use VLC as media player .. then:
1-Download (Subtitle Edit 2.9.3) software .. it's free!.
2-after setup .. open the subtitle (.srt file ) and adjust "defult file encoding" (same window-left side) to: UNICODE
4- Save (from file tab).
5- You can also adjust the time (later or earlier).
In case you have any questions, my e-mail:
[email protected]
Enjoy..Regards
Ahmed Hosny [Egypt]
Posted on Oct 27, 2010
I need to update the software of my LG DV532how can i acieve that?
You dont need to update your software of your dvd,you just need to make sure your dvd usb supports arabic or just do this, Search your movie in google with SUBTITLE ex.Superman subtitle, then if you found your language download it, usually it is a .zip file when you download it ex Superman subtitle.zip you will need to extract that using winrar or any extract tool, after extracting the file should end with .srt ex. superman subtitle.srt, if it is, make a folder in your usb then copy the movie and subtitle in it (make sure the movies name and subtitle name are the same ex. superman.mp4 and superman.srt) then play it.
4answers
I have downloaded an srt file but computer cannot open it
srt file is subtitle for video and played with a movie. You can open and view an .srt file with a subtitle editor program like Subtitle Creator or open via webbrowser.
1helpful
2answers
I have a serious problem...i wont to see movies with greek subtitles and every time i put the srt file in my movie file (avi,divx etc...) it seems that its added but when the characters starts speaking,the...
Firstly i am not able to understand your problem correctly.What i think your problem i am writing solution according to that.
Try playing in different player or better player like vlc which can play all types of media files.
May be there is some problem in your player caching.As caching needed everytime u play a movie.Try uninstalling your player then reinstalling.
Hoping this will work
50helpful
5answers
Hi, how to enable subtitles for DivX movies from USB on LG 42LE5500? I connect USB, TV recognizes folder where DivX .avi file is but within same folder it does not "see" .srt subtitle. Also, in settings...
It seems that subtitle file must have exactly same name as movie file. For example: Movie file: Mission impossible.avi Subtitle file: Mission impossible.srt or Mission impossible.sub or Movie file: Mission_impossible.avi Subtitle file: Mission_impossible.srt
7helpful
3answers
32LG80FR LCD TV, Arabic subtitle problem
you follow your user giude and setup language
1helpful
CanĀ“t see subtitles
Open the .srt file with wordpad and save as a .txt file. Now it will show the subtitles.
2answers
Divx subtitle problem
i did too have the same problem & i call back ther service center , he told me only the original movies with the orignal sub titles that can be played
How i can view divx whit subtitles (.srt, .sub.ssa)?
Look for firmware upgrades in Samsung's website.
You have to download a set of files, burn them on to a CD or DVD (check the help file in the download) and then insert the CD or DVD to your DVD Player and follow the on-screen instructions. It is really simple, just make sure you download the correct upgrade from the website. And one advice, use a RW DVD or RW CD because you may have to try it many times ;) .
6helpful
2answers
Divx greek subtitles
look in the menu and try to change the encoding, There should be 3 options, Unicode, Cyrilic & Greek. Select greek if the .sub or .srt file is in ANSI encoding, or select Unicode if the file is in UTF-8 or Unicode encoding.
To find out the encoding of an .srt file the simpliest thing to do is open them with notepad and got to "File" -> "Save as", The encoding should appear in the bottom of the dialog.
2helpful
3answers
it is quite easy to play those anoying subtitles first name the same way both files (video file and subtitle file) example movie.avi movie.srt be sure that both files are in the same folder second: insert the cd/dvd in the yht-630 when the menu appears select the subtitle file using the arrow keys and press the "subtitle" key after this at the screen you will see -> subtitle selected finally select the file that contains the movie (again arrow keys) and press "ok" or "play " key the movie will start and the subtitles will appear. it functions with sub and srt files
Pioneer DV-350 DVD Player Logo
Top Pioneer Televison & Video Experts
Ekse
 Francisco Mauricio...
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
