the fax hackers are still researching the method to disable plug-n-print chipcard in magic 5 series. magic 3 series has been solved in hidden service menu.
This means you need to buy a new inkfilm with new chipcard included. sorry.
First of all make sure why cover is not closing .check its locks.for to change roll just see iside the machine i am sure there will bi a printed paper from manufactrer with picture how to change a roll .it will tell u the direction of roll.by following the picture just change it MIAN AKHLAQ
On inside of machine it states how to: 1. Place new paper roll on the left hub while pushing it in, lowering the roll into the compartment making sure it is inserted onto the right hub. 2. Pass the leading edge of the paper through the paper cutter guide and the cutter. 3. Remove any slack in the paper. 4. Close the cover. The paper will feed out automatically.
Have just tec support (10p per min robbers !!) Here is what you do OPEN MACHINE
WITH THE NEW INK FILM IN, ROLL THE INK FILM ON ROLLER NEAREST TO YOU FORWARD UNTIL ALL THE SILVER STRIPS TO THE RIGHT ARE NO LONGER VISIBLE (THIS IS THE BAR CODE ON THE INK ROLL IT'S SELF)
REMOVE INK FILM FROM MACHINE
CLOSE MACHINE
TYPE IN OK 45 OK 7117 OK (THEN IT WILL ASK IF YOU ARE SURE) YES (CHANGE WITH < > BUTTONS BETWEEN OK BUTTON )
WITH
CLOSE MACHINE
TYPE
