Question about Dometic Rooftop RV Air Conditioner
Have a Dometic Penguin on the front of a 5th wheel with mech. Controls but compressor only runs for a short time & takes a long time to start again new unit
  • Mike Butler
    Mike Butler May 27, 2010
    Can you give more details? Manual controls at ceiling? Obviously not a ducted system?
Mike Butler
  • Dometic Master
  • 6,674 Answers
Have you checked for frost on coils/fins when you remove filter at ceiling assy? Non-ducted I presume?
Posted on Jun 05, 2010
  • Pamela Roach Sep 23, 2011
    samething happened to our new penquin it was the circuitry in the bottom of the air conditioner. Dometic replaced the bottom of the air conditioner that is on the ceiling in the bedroom. This piece is all one unit
Ac compressor runs but will not cool
check thermostat, replace capacitors amp compressor to be sure its running if not relay module issue.
Aug 08, 2015 | Dometic 651815 Duo Therm 13,500 BTU...
I have a dometic penguin ac rooftop unit. Model no. 630215.421. Fan blows Compressor does not kick on. Fan blows just no cold air. If put on auto and go up or down in temperature On the thermostat The fan...
Bad run capacitor or bad compressor. If you hear an occasional click from the compressor try a new run cap and then a hard start kit. Otherwise it's more economical to purchase a new unit.
Sep 25, 2013 | Dometic Rooftop RV Air Conditioner
Have a Dometic Penguin on the front of a 5th wheel with mech. controls but compressor only runs for a short time & takes a long time to start again new unit
It sounds like your compressor is overheating and going out on internal overload. It takes awhile for the compressor to cool back down before the overload resets itself and allows the compressor to attempt to restart. This could be a refrigerant problem that could be costly. However, it is very likely to be something less expensive also. First, open up the control section and look for any wiring or connections that appear damaged, loose, or overheated and correct as necessary. The compressor will use a capacitor. When these capacitors fail, they will cause the compressor to overheat and go out on overload. Test your capacitor and replace as necessary. Of course there are a wide range of items that can cause this problem, but these are the very most common (and least expensive) solutions that you can check yourself. The capacitor can be taken to a shop that carries this part and they should gladly test it for you.
If you have low refrigerant or a locked up compressor, it will be costly and you will need to decide (based on age & condition) whether it is more beneficial to you to repair or replace your unit.
Without being onsite with toolbox in hand, I hope this has been very helpful to you moving forward. :-)
Apr 30, 2010 | Dometic Rooftop RV Air Conditioner
Brand new Duo Therm won't stay running
You really need an Ammeter to check this problem. Just because it is a brand new unit does not mean that there isn't a problem with it. Is it run off of a wall thermostat or manual controls? The compressor has a thermal overload switch on the top (under the plastic cover) that will take the compressor out of the circuit if it gets too hot. However, if the entire unit is shutting off, there is another problem. Selector Switch? Thermostat? Let me know what kind of controls you have and we can go from there.
Jul 01, 2009 | Dometic Rooftop RV Air Conditioner
My Dometic 620315 Penguin roof a/c does not produce cold air.
If the compressor is running with no cold air the unit is more than likely no good. It can not be recharged. you need a new unit. If the compressor is not running you need to check the capacitors.
Mar 16, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
231 people viewed this question
Top Dometic Heating & Cooling Experts
Marvin
Marvin
Sheldon Dedek
Mike
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
