Http://www.bikebandit.com/houseofmotorcycles/2005-honda-motorcycle-vt750dca-shadow-spirit-carburetor-component-parts/o/m2904sch406961
Not to sure about this one, ok, if the choke wont stay out, then try to trace the choke cable to the carby, have a close look and see which parts move on the carby when you activate the choke, some thing just needs to be tightened up, so that the choke stays on. Also, you say the bike stalls and runs rough, is this with the choke on? If yes, then that is just a sign that you dont need so much choke on. Just try half choke. Do you live in a warm climate? if so, then you dont need much choke . So there is no adjustment really, only by the amount of choke you apply. Also remember, never use the choke if the engine is already warm. And, only use the choke for the first start of the day, when the engine is stone cold. The correct way to to start a cold bike engine is, pull the choke on fully, crank over engine, but DO NOT give it throttle, (this defeats the purpose of using the choke), when engine fires up and starts, slowly push the choke in till a smooth, high idle is acheived. You should be able to ride off slowly, and push the choke off after about a mile.
SOURCE: 2006 Honda Shadow Aero starts but won't idle.
check fuel level, u may need to check the flow of petrol to it,,Also if that does not solve you may need to service the carb and check fuel filter,air filter etc...
SOURCE: 2005 honda shadow spirit 1100. runs with choke on
Have you tried to adjust the tickover screw on the carbs?
SOURCE: Front brake too stiff on 1984 Honda Shadow VT500C Shadow
You should have disc brakes??? They are not adjustable.
It is common for a caliper piston to freeze up or become corroded and bind up so it will not move freely.
SOURCE: Should I adjust my valves? 1999 Honda Shadow Ace.
Well if its running good and you don't here any out of the ordinary rattling I wouldn't worry about it until at least 25,000-30,000 miles on the bike so probabley in another 10,000 miles or so have the valves adjusted unless you hear any unordinary rattling noises sooner then go in at that point and have them adjusted.
SOURCE: 2002 Honda SHADOW SABRE It wont stay running unless it's
More information is needed - aftermarket pipes? any carb work been done to it? is fuel fresh? air filter condition? how are the plugs burning? oily black, white/tan?
why does it need adjusting? is it not pulling on all the way?
The Choke Won't Stay Out The Bike Stalls And runs Rough
