Abit AV8-3rd Eye Motherboard Logo
Posted on May 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Abit av8 bios post codes 8.3 - 8.6 - 9.c What is failing on boot ? I get one long beep followed by 4 short beeps. I have swapped video cards and reflashed the bios with no help. If I reboot 2 or 3 times the computer will eventually boot.
Anonymous
Level 3:
  • Master 1,138 Answers
  • Posted on May 24, 2010
Anonymous
Master
Level 3:
Answers
1138
Questions
Helped
432476
Points
3620
I still did not find beep code that match your problem..
Anyways here are the common beep codes for your motherboard.. it might help you too.
1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem.
2. 1beep - board is working fine.
3. One long beep then it shuts down - cpu problem, your processor is not working or missing.
4. 1short beep - system boots normally
5. 2short beeps - CMOS setting error.
6. 1long 1short beep - dram error
7. 1long 2 short beep - video card or monitor not connected
8. 1long 3 short beep - keyboard error.
9. 1long 9short beep - ROM error
10. Long beep - memory card is missing or not connected
11. Short beep - power supply error
12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
Hope this gave you an idea of your problem..
Much appreciated if you rate this help..thanks..
1 long beep in post
Hello one long beep, is a failing ram module.
Try to renew the modules, or remove the modules, and insert one at the time.
Just to test one of them for fault.
4x 240 Pin DDR2, Dual Channel DDR533//667/800, up to 8 GB
Here is a list of beep codes:
http://www.computerhope.com/beep.htm
One short beep is normal.
Good luck
I have an abit av8 mother board and am tryng to install a new power supply (G7 powr exteme) the LED2 is flashing with with no constnt power availabe to power up te system please help is my board or th
Hello here is the homepage:
http://abit.ws/page/mi/download/download_driver.php@pFUN_KEY=9000&pTITLE_IMG=_2Fdownload_2Fimages_2Fdownload.html
You have probably connected the +12 volt 4 pin, connector wrong.
The pci-e graphic connector, sometimes fit here.
When this happends the mainboard will not boot up.
Try to read the manual for the power supply.
Good luck
When i boot up the computer it starts beeping immediately, otherwise boots just fine
The beeps are part of the boot sequence, more normally called the post report. The beeps length and number usually indicate a problem.
Check with the abit website, you need the post sequence for your motherboard.
Usually, with a post report, you get a single beep which means everything is tickety boo.
CANT MOVE AROUND IN THE BIOS
Do you think about set up bios? ,If so follow the bello links,
Start and pres F2/F10/Dell
BIOS SETUP BOOT CD YouTube - Acer aspire 5580 Main Unit Disassembly.flv Repair4Laptop: Laptop & Notebook Repairing, Upgrading and Modding Guides: by Manufacturers http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/ Laptop Parts 101 CD-Rom support from Bios Phoenix BIOS setup and help BIOS - The setup program used in desktop and laptop computers/PCs - Page 1 of 2 Hope this helps.
If you are helped you can rate on the 4 thumbs and post a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
When i boot my pc the led get to 8.6 then goes to 9c i then get one long beep followed by four smaller beeps
Memory refresh toggle test failed
Try one Memoryblock
I think your memory is bad
3helpful
3answers
Abit AN7 motherboard does not boot - POST code AF
i think thats memory so try removing your ram and re installing it. maby its not pushed in all the way.
Abit beep codes?
Here is a good discussion on the ABIT Beep codes. See if this helps you.
http://www.ocforums.com/showthread.php?t=218664
Good Luck,
Paul
AV8 Motherboad post code C5 freezes on boot.
Hi...
Try cleaning the contact point of the memory modules "with a pencil eraser" and insert them back... Clean also the Processor heat sink if dusty... Then check the voltage of the CMOS (3V) battery it maybe dead, if so you need to replace that with the same type.
Keep me posted if still does not work...
Happy fixya...
Recieving error code FF and pc will not boot/recognise harddrive
the problem it is in harddisk
is that u have ur smp (power supply)
just check the power supply & insert the cable
properly in to the slot of motherboard & check whether the display has come if it comes than boot the xp cd if problem occurs go to nearest shop of computer
Top Abit Computers & Internet Experts
ExpressFiX
ExpressFiX
JTR44
Level 1 Expert
Grand Canyon Tech
Grand Canyon Tech
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
