I own a lg fully automatic washing machine front loader (model:WD-8074FHB)i dont have an owners manual. My question: There are 3 sections. 1st section is for washing detergent. Which of the other 2 are meant for 'softener'? The middle? or far right? anna
Anonymous
    New Friend:
  • 4 Answers
Hi Anna, As you face the machine the left section of the draw is for the main load washing powder, the middle section is for fabric softener and the right section is for the pre wash powde.
Hope this helped :-)
Posted on Jun 07, 2010
My LGfront end loader washing machine is shaking so bad it actually walks across the laundry room 3 -4 feet
I had the same problem when my LG WD-8074FHB was new. LG recalled them and put a larger weight in them. The weight is a hollow piece of plastic filled with concrete in the top of the machine under the cover. It stopped it moving around the laundry.
Mar 04, 2014 | LG WM1814CW Front Load Washer
Can you provide a link to a LG Front Loader WD-8074FHB service manual
checked this site for your LG washing machines..
http://www.manualsonline.com/ex/thread/view/idThread/1035082
Mar 05, 2011 | LG Washing Machines
LG front load washer WD-8074FHB the circuit board exploded into little bits during a cycle. I bought a new board but when I connected it up there is no power or display on the new circuit board. What else...
if the curc bord exploded i would blame either power overload. or water in the curc the lg- wd units have both internal p.c.b bord fuses as well as in line fuses try checking them
Jul 07, 2010 | LG Washing Machines
Is there a filter in the LG INTELLOWASHER 7kg. If so where is it. The model is WD-8074FHB
its located on the bottom right of the machine front - open the flap and you will see a round filter base. ONLY OPEN THE filter during the last of the spin cycle to clean it, this is when most of the water has been pumped away. Opening it while the machine is off will cause a gush of water over the laundry floor.
Feb 08, 2010 | LG Washing Machines
Which compartment does my detergent/fabric softener go in?
You can get all of Whirlpools user guides here:
http://www.whirlpool.co.uk/app.cnt/whr/en_GB/pageid/pgsrvifuhome001/ifu/home Generally the one one the left - is for pre-wash (if clothes really soiled), the middle one is for powder (if you use it) and the last one is for softener or bleach.
I just use liquitabs - which go directly into the drum, and fabric softender.
Jun 16, 2009 | LG WD-16110FD Front Load Washer
LG WD-8074fhb
Your problem is either in the control board or the water level switch.  The computer can't tell if the water has drained or the control board is stuck in the 8 minute drain cycle.  Recommend pulling the plug and wait 5 minutes to reset the computer.  If the problem persists, it will require an LG experienced tech to see what's going on.
Mar 14, 2008 | LG WM1814CW Front Load Washer
sometimes you just have to force the door but first try hitting the machine near the door lock sometimes this helps the door interlock may be stuck in the closed position
Mar 02, 2008 | LG WM1812C Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
