Cell Phones Logo
A
Anonymous Posted on May 21, 2010
I have a lg wine cell. i went to turn it off today while inside a hospital and since then will not turn on. All it does is flash the lg symbol on and off? it had a good charge to it ?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 23, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
180
Points
Having the same problem here, did you find a way to fix it?
How do i reset my lg wine 2
See this... http://www.resetcellphone.com/solution/LG/un430-wine-2
Need a manual for the LG280 cell phone. Want to know how to answer my 2nd line when it rings.
http://www.lg-cellphones.org/lg-wine-user-manual-lg-wine-ii-user-manual.html
Try this. Often, slightly different models tend to be nearly identical, except for a feature or two. This may be similar enough to help you.
Dec 20, 2010 • Cell Phones
5helpful
CANNOT GET PICTURES OFF LG WINE PHONE !
go to lg's web site and download it..its free
10helpful
2answers
How can I connect an LG Wine to my computer to change ringtones, update contacts etc. I used to have a motorola and the phone tools was awesome is there something like that for LG?
The data cable does nothing but charge the phone. If you have a bluetooth enabled computer, you can move data. This is from the LG message boards.
14helpful
How do you use a breville wc15xl wine chiller
HOW TO USE
First you place the Wine Cooler on a flat, dry surface, making sure that the timer is in the "off" position.
Remove the chill cells from the freezer and place around the inside of the cooler.
Thirdly, place the bottle inside the cooler and then pour cold tap water inside, until it just covers the top of the chill cells.
You can then plug the unit in, or if it has batteries you don't need to.
Finally, you set the control dial to the desired time. The following are recommendations for different types of beverages:
Sparkling Wine, Champagne and Dessert Wine.....9 minutes
Dry Wines, Sauvignon Blanc, Riesling.....6 minutes
Chardonnay, Rose'....5 minutes
Light Red Wines, Pinot Noir....3.8 minutes
Full Bodied Reds, Shiraz, Grenache, Cab Sauvignon, Merlot....3 minutes
If you choose to chill a beverage without the timer, you just turn the control to the left and when you are done you turn it to the off position.
In addition to wine, the cooler can also chill beer and soft drinks. The only limitation is that the bottle diameter can be no more than 3.75 inches.
Should you wish to chill two or more consecutive bottles, the cells will remain cold enough for you to to do so.
While not in use, the cooler can also be used on the table with ice to keep your beverages cold (much like a regular ice bucket).
The power cord is removable, which makes for an easy clean-up.
The unit comes with a manufacturer's One-Year Limited Warranty.
2helpful
2answers
LG WINE manual owners
Hello!
You can get the LG Wine user manual here:
http://www.bell.ca/support/PrsCSrvWls_ClpGde_Interactive.page?brand=lg&model=wine&sku=97193#
Copy the complete link into your browser and you will have the manual in PDF.  If your not set up to read PDF files, get the reader here for free from www.adobe.com.
I hope this helps you out,
Ken
Jan 07, 2009 • Cell Phones
Scrren went gray
the screen is dead, take it to your local cell phone service provider
1helpful
2answers
Deleting text messages
i had this same problem just turn your phone off wait about ten minutes turn it on and it will delete them all
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
